Question about Car Audio & Video
Kenwood cs5370 Oscilloscope channel 1 out of order. VALDEMAR
I bought an used KENWOOD CS-5370 Oscilloscope. It is working the Channel 2...but channel 1 is out of order...trace for channel 1 only appears on screen when it is grounded to GND...it seems someone has applied overvoltage or the like to channel 1 and make it defective...I am in need of the Service Manual to check input 1 and its circuitry. Who help...??? Thanks you, VALDEMAR
pjstanley
  • 185 Answers
SOURCE: one of 2 subs stopped working.
ya the sub is blown or the amp channel is blown
Posted on Apr 10, 2008
tech48
  • 624 Answers
SOURCE: Kenwood - KDC-1020, Service Manual or
This is the standard Kenwood wiring harness from the service manual,
Let me know if you need more help.
I would appreciate a good rating if this was helpful to you.
Thanks
Posted on Jun 20, 2008
  • 7 Answers
SOURCE: Wiring a Kenwood KSC-WD250 Subwoofer
7e83231.jpgi had the same problem Here is the diagram i used from someone else on fixya.  Thank you.
Posted on Jul 21, 2008
  • 150 Answers
SOURCE: Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
Posted on May 10, 2009
  • 8 Answers
SOURCE: how to wire kenwood amp to kicker cvr 12"
If it is a Kenwood Kac 9105d it factory specs say it is not 1 ohm stable.
Posted on Dec 03, 2011
How to modify kenwood th234 from channel mode to vfo mode?
[PDF]Page 1 INSTRUCTION MANUAL KENWOOD ...
manual.kenwood.com/files/B62-0790-10.pdf
o Contains 60 memory channels programmable with desired frequencies and ... o Do not modify this transceiver unless instructed by this manual or by ... BASIC TRANSCEIVER MODES . ..... 1 Press [VFO] to select VFO mode. P1'I switch, and ...
[PDF]INSTRUCTION MANUAL - Kenwood
manual.kenwood.com/files/TH-D7-English.pdf
memory channel to be named using up to 8 ... Do not modify this transceiver unless instructed by ...... In VFO or Memory Recall mode, use the keypad to select a ...
Modifying the Kenwood TH-78a handheld transciever
www.welcomehome.org/rainbow/.../kenwood/kenwood-th78-mods.html
Nov 17, 1995 - (When William's early-model TH-78 was upgraded his mods (removed .... channel (if in memory recall mode) or last frequency (if in VFO mode).Missing: th234
Dec 21, 2015 | Phylrich Mirabella 3/4 Inch Thermostat,...
Can a pair of Kenwood TK 3160 work with Baofeng BF888s I have a Baofend and another coworker has the second Baofeng.Our shipping office bosses have Kenwood TK_3160 can they share channel 7
Here goes. Yes, your Baofeng Ham radios could be programmed onto a business band channel. Yes, it could transmit. BUT, ham radios do not meet the stringent requirements that Business Band radios do. This refers to channel spacing, interference and a long list that Business radios are required to have to make operation legal. Therefore, your Baofeng makes a great scanner. Business band frequencies are to be used by radios meeting these stringent requirements in order to prevent interference. Failure to follow the FCC Rules could result in a hefty fine. Didn't you wonder about the price difference?
Apr 15, 2015 | Kenwood Programming Cable Tk2160,tk3160...
What is the rms outpur of my kenwood KAC 848 amp
rms at 4 ohms is 50x4 in 4 channel mode if your in 2 channel mode then its 150x2 if at 2 ohms then it would be 4 channel 75x4.
Jul 28, 2010 | Kenwood KAC-848 Car Audio Amplifier
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
Radio
Hello george_nutti,
The model number you posted is for a center channel speaker which has no controls, and not knowing the exact model number it's difficult to be specific.
Some Kenwood KDC models allow you to select one of 3 "tuning modes", 1) AUTO1 - Automatic search for stations; 2) AUTO2 - Search Preset stations; 3) MANUAL - Normal manual tuning control. If your Kenwood is one of these models, you need to set the tuning mode to MANUAL. For Kenwood Excelon HD receivers, direct access tuning is done by using the included remote. 1) Press DIRECT button on the remote; 2) Press number buttons to enter desired channel number; 3) Press DIRECT button again to exit direct tuning.
Hope this helps.
Sep 08, 2009 | Kenwood KSC-310CCS Center Channel Speaker...
Need manual for kenwood tk-270 transceiver does any one no were i
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor KeyOff = off1 = Monitor momentary2 = Monitor Lock3 = Squelch off momentary 2. Scan KeyOff = offCo = carrier operateTo = Time operate 3. Dial KeyOff = offOn = enable 4. TA keyTA = talkaroundRV = ReverseOff 5. Lo KeyOnOff 6. PriorityNone1 = fixed2 = selected 7. Fixed Priority ChannelTurn selector to channel 8. Look back time ATurn selector to time in seconds 9. Look back time BTurn selector to time in seconds 10. Revert Channel1 = Selected2 = Last Call3 = Last used4 = Selected + Talkback5 = Priority6 = Priority + Talkback 11. Tx Dwell timeTurn selector to time in seconds 12. Drop out delayTurn selector to time in seconds 13. Time out timerTurn selector to time in seconds 14. Tot Pre-alertTurn selector to time in seconds 15. Tot Rekey timeTurn selector to time in seconds 16. Tot reset timeTurn selector to time in seconds
Apr 27, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
I was given a kenwood kac742, what do i have to do to hook up 2 subs to it tom
You need:
1) 2 4-ohm subs
2) Appropriate enclosure
3) Amp wiring kit with RCA's
Connect each sub to a separate channel and set both mode switches to "MONO" (center position). In 2-channel mode, this amp is only rated at 80 Watts RMS, so you need relatively small and efficient subs. I'd say nothing bigger than 8" or perhaps 10". Rockford-Fosgate P1S48 (8") and R1S410 (10") will work OK with 50-150 watts RMS. Some others will also.
Mar 25, 2009 | Kenwood Car Audio & Video
The amp is only putting out on 1 channel
I do believe this is caused by one of your amp fuses. Depending on which + on the amp is being used. That channel has a blown fuse. have you tried running + and -, + and - to both channels to see if both subs worked? If one sub doesn't then it's a blown fuse or scarred fuse and needs to be changed.
Feb 10, 2009 | Kenwood Excelon KAC-X521 Car Audio...
Ok i basically have a kenwood kac-6404 amp and its a 2/3/4 channel i was wondering how i can alter them or switch it from 2 to 3 to 4
i guess there is no switch. its how you wire the outputs together to create 1 channel from 2 channels. consult the wiring guide that goes with your amp
May 15, 2008 | Kenwood Car Audio & Video
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
