Vizio tv no signal
My vizio is not working its saying there is no signal it is brand new
    Problem Solver:
  • 15 Answers
Vizio's have an input button on the remote. Be sure to check all of the connections listed. It is important to know how your cable plugs into your TV. I.E. Cable, HDMI, etc. looking at where it is plugged into on the tv will help you to ensure that you have the correct input chosen. Also be sure your cable box is turned on. If it is off or unplugged your vizio TV will not register a connection.
I hope this helps!
-Rogue
Posted on Jan 02, 2014
SOURCE: Vizio "no signal"
We just had this problem and it was the cable that came with the set. Once we replace this, it received a picture, however, now the volume and on/off does not work on the Verizon remote.
Posted on Mar 09, 2008
SOURCE: VIZIO 42" Flat Panel Televisions keep cutting off and saying no s
Check the input source connection cable
Posted on Sep 16, 2009
  • 145 Answers
SOURCE: hdmi not working
Probably a bad port, but if you can get the TV near a PC or network connection, I highly recommend Vizio's customer service. They will be able to test for exactly what is wrong, and possibly even push out a software fix to repair it. If it cant be fixed with software,, they will get a certified tech out to handle it for you.
Posted on Apr 02, 2010
BeckiB_DISH
  • 286 Answers
SOURCE: Our new vizio tv is
Hello. This is usually an easy issue to fix. To get the DISH Network back on the screen, i have included a few steps:
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable, then the TV will need to be on an HDMI input
If you are using Component cables, your TV will need to be on a component input. (Usually Comp 1 or 2)
If you are using RCA cables, then the TV will need to be on a VIDEO input (Usually Video 1 or 2)
If you are using COAX cables, then the tv needs to be on channel 3 or 4 (If you are at TV2, then the TV needs to be on channel 60 or 73)
Becki Barned
DISH Network Customer Service
Posted on Feb 28, 2011
SOURCE: My 42" Vizio TV turns on and says No Signal, then
push INPUT on remote, select the input source you want, keep changing channel to find a exist channel.
Posted on Mar 25, 2011
Screen on my 2007 vizio flatscreen tv went black but the sound still works. i called the only repairman in town and he says not worth fixing.too expensive and vizio not a good tv. what's you opinion.
I think Vizio's are decent televisions, you may have been unlucky. Saying that, I do agree with the repairman,, by the time you get the television fixed the bill will be close to the price of a brand new televsion.
Feb 02, 2016 | Vizio Televison & Video
Subtitle choice grayed out on vizio e390i-a1
You are confusing subtitles with closed captioning (CC).
May 13, 2017 | Vizio E390i-A1
When I plug a brand new HDMI cord into my Vizio VA26LHDTV10T it says
Have you used the input display ie usb freeveiw hdmi avi ect because your tv will have a input display ?
Sep 07, 2012 | Vizio VA26LHDTV10T 26" 720p LCD HDTV
I am having an issue with my rgb connection, it was working one night the next it says no signal.. what could be causing this? the tv is only 6 months old the cables are brand new as well..
Tries take out and plug in RGB cable back in/out for a couple times,should solved this connections problems mishap.Dose not solved the problems.Return the tv set and get a new tv replacement tv have cold soldering in RGB joints connections somewhere.
Aug 20, 2011 | Vizio L32 32 in. LCD HDTV
Mar 25, 2011 | Vizio 42 in. LCD TV
Vizio TV with Blue Screen says, "Aucun Signal!"
Guys aucun signal just means no signal in french
Mar 01, 2011 | Vizio L37 Television
The LED vizio comes on the front of the tv...........screen is blue with floating signal saying No Signal!.
Tries unplug the tv and the cable or satalite boxes too.Replug it all back like an hour later.The tv know will reset itself back to the factory setting.The cables or satalites boxes it upgrading it softwares.The tv should have incomming broadcasting signal and work now.Not,call the cables or satalites compannies to replaced those inputs boxes first,have the same problems with those new input cables or satalites boxes.Than the tv,the Tuner signal board have problems and the cause.That the board,where the incomming broadcasting signal cable plug into it.That the tv Tuner signal board.Tries websites Shopjimmy.com,Ebay.com to buy a whloe refurbish Tuner signal board for the replacement.
Nov 07, 2010 | Vizio VX32LHDTV10A 32 in. LCD HDTV
CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Aug 12, 2009 | Vizio L32 32 in. LCD HDTV
VIZIO VO42LF says no signal when connect to PC after power on/off
Could be a sensitivity problem, have you tried to switch tv modes back and forth, sometimes if you do that it will save you from restarting the computer. I had a tv about 10 years ago that had a sensitivity issue, went to see about fixing it, unfortunately, the tv brand was no longer in the country and user service parts were not available.
Apr 11, 2017 | V, Inc. Vizio P4 Plasma Television
Black screen says no signal
check your inputs and verify that you have the components hooked up correctly or snug. try running a new scan in the tv mode
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
339 people viewed this question
Top Televison & Video Experts
Electro Med Services...
