Question about Xerox Phaser 8560N Laser Printer
Print Quality Problem
Showing a dark smear about an inch wide all the way down the page.
  • adi May 11, 2010
    have you tried an eliminate light stripes routine?
    Novelist:
  • 125 Answers
Hi jepeto997:
Try these steps.
Check for and remove any media, jammed
paper, or debris found in the printers exit
path.
2. Did this correct the problem?
Complete. Go to Step 2.
2 1. Clean the maintenance kit wiper blade or
replace the maintenance kit.
Complete. Go to Step 3.
3 1. Check the exit area, exit frame, the
preheater, maintenance kit, and the
printhead (including the paper release blade)
to see if there is anything touching the drum
assembly.
2. Reseat any printer component interfering or
touching the drum assembly.
If there are streaks on the front side only of a
2-sided print, the preheater may be scraping
ink off the print.
2. Look for ink shavings along the streaks on
the printed paper.
3. Clean the preheater using the Control Panel
Remove Print Smears function.
4. Did this correct the problem?
Complete. Go to Step 5.
5 1. Possible weak or missing jet. Print the weak/
missing jet test print from the Control Panel,
see "Weak/Missing Jet" on page 5-33.
Complete. Go to Step 6.
6 1. Possible discolored jet. Print the solid fill test
print, see "Black, Red, Green, Blue, Cyan,
Magenta, and Yellow Solid Fills" on
page 5-40.
Complete. Go to Step 7.
7 1. The X-axis drive is not functioning correctly.
If the X-Axis Drive does not move the
printhead smoothly and evenly during
printing, vertical lines appear on the print.
For information about X-Axis Drive
problems, see "White Stripes (Pinstripes)"
on page 5-30.
Complete. Go to Step 8.
8 1. Smears on a duplex print can be caused by
the paper preheater operating at a
temperature that is too high or debris is in
the duplex roller or duplex paper path
guides.
2. Run the service diagnostics Duplex Path
test to check the paper preheater’s
temperature.
3. Is the operating temperature within the
correct value range?
guides.
temperature.
Replace the
preheater.
Replace the
electronics
module
Hope this helps
3. Clean the paper release blade.
Posted on May 24, 2009
How do I repair a thick black line going down the page?
Hi Ydn2,
You need to say what type of machine, what colour, what conditions. etc,etc.
Good luck.
Feb 26, 2015 | Xerox Phaser Office Equipment & Supplies
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Smear on right side of paper entire length of paper all colors
Follow the below instructions to clean the printer through the control panel:
  1. Press MENU to enter the MENUS .
  2. Press (Down arrow) to highlight CONFIGURE DEVICE .
  3. Press (Select) to select CONFIGURE DEVICE .
  4. Press (Down arrow) to highlight PRINT QUALITY .
  5. Press (Select) to select PRINT QUALITY .
  6. Press (Down arrow) to highlight CREATE CLEANING PAGE .
  7. Press (Select) to select CREATE CLEANING PAGE . A page with a pattern prints from the printer.
  8. Remove all paper from Tray 1.
  9. Remove the cleaning page and load it face-down in Tray 1. NOTE: If not still in the MENUS , navigate to PRINT QUALITY using the above instructions.
  10. At the printer control panel, press (Down arrow) to highlight PROCESS CLEANING PAGE . This option will only be visible in the menu when a cleaning page has been printed.
  11. Press (Select) to select PROCESS CLEANING PAGE . The printer control panel displays the message Cleaning... . The cleaning process takes a few minutes.
let me know ....
If I could be of further assistance . If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | HP Color LaserJet 3500 Printer
HP LaserJet 2200 Series PCL huge dark smudge
Replace toner cartridge. If problem persist replace fuser unit. P/N # RG5-5559
Apr 28, 2009 | HP LaserJet 2200D Printer
Faint horizontal dark line about 2 1/8 inches down from the top
You can easily fix this yourself, one of the quickest ways to fix it is to print 10 doublesided blank pages and it will clean the inside of the machine for you and the line will vanish.
For further print quality problems on this machine follow these instructions to troubleshoot.
When troubleshooting image quality problems, it is important to understand the situations in which the problem occurs.
Print a copy of the color test pages to determine whether the problem is in one color or more than one color.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Color Test Pages], and then press the [OK] button to print the test pages. If the problem occurs with one color on the test pages, perform the solutions for this problem. If the problem occurs in more than one color on the test pages, restart your search and select a case for the image quality problem occurring through all colors.
Mar 27, 2009 | Xerox Phaser 7400/DXF Laser Printer
NO PRINT I INCH WIDE DOWN SIDE OF PAGE
try removing your toner cartridge and giving it shake back and forth. If this improves the quality, i would get another one, as it is likely nearing end. Otherwise, it is likely an optical problem, and will need service.
Mar 20, 2009 | Sharp AL-1642CS Copier
Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Nov 19, 2008 | Brother MFC 9600 All-In-One Laser Printer
Print Quality problem Xerox 7400DN
Opening a cover during printing will cause a paper jam. If you do this several times and carefully clear th paper you may be able to isolate the origen of the smudging.
Jul 17, 2008 | Xerox Phaser 7400DN Laser Printer
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Xerox Phaser  8560N Laser Printer Logo
414 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
