Question about Pride New Jazzy 600 Power Wheelchair by Mobility
How do you power cycle on quantum 1450 electric wheelchair
Where are the Quantum 600 Fuses Located?
Ron,
With a gifted power wheelchair, the usual culprit is a pair of dead batteries usually size 22NF deep cycle batteries. The pediatric chair may have U-1 (35 amp hour batteries) There are fusible links connected to both batteries at the + terminal. There are additional fuses under the rear cover in booted holders in the belly area in the rear near the controller. These power take off harnesses are fused but probably do not relate to your primary dead battery problem. Remove the front cover of the base and pull out the battery tray. Remove the batteries, test, and replace.
The owner's manual can be found here. It also includes basic service. Hope this helps.
http://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_q600_series_om.pdf
Jul 22, 2016 | Quantum 6000 Power Chair - Used Electric...
My quantum 600 wheel chair won't work it says system lock
My quantum 600 wheel chair won't work it says system lock ...
www.fixya.com/.../t26033304-quantum_600_wheel_chair_work_says_s...
2 hours ago - My quantum 600 wheel chair won't work it says system lock -Wheelchairs question.
Pride Mobility Quantum Q6 Edge (Power Wheelchairs ...
www.usatechguide.org/itemreview.php?itemid=1626
Quantum 6000 or 600 Rehab Power Wheelchair - CareCure Communitysci.rutgers.edu/.../showthread.php?...Quantum-6000...Rutgers UniversityJul 4, 2008 - 10 posts - ‎9 authorsI had the QUANTUM 600e Rehab Power Wheelchair for six months. ... C-500 Hvy dutypower chair w/hi-speed motors, power seating system, .... I have a Q600 with tilt, recline, leg extension, Q-logic..pretty much the works. ... the thing shuts itself off andwon't move when I have anything under 90% charge?Quantum® 600 Power Chair Reviews - Pride Mobilityownersclub.pridemobility.com/reviews/item/1/20The Quantum® 600 Power Chair delivers the stability of patented Mid-Wheel 6® ... At that same time the 3rd motor set was changed my seating system was ... We were rescued by boat and my friends say the wheelchair was working ... Insurance won'tcover a power chair for me yet so I had to pay out of pocket for this one.
Jan 01, 2016 | Health & Beauty
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Dec 30, 2015 | Quantum 600 E Electric Wheelchair - Used...
Quantum 614 #203 Brake 1 and 2 disconnected
How can i fix break #203 and 204 disconnection problem on quantum 6000 wheelchair. Thanks
Jun 04, 2014 | Quantum 614 HD Power Chair - Used Electric...
Error code 80 and then 138 quantum edge w/c
Low voltage. Check the batteries and connections to the power module and joy stick. Make sure no loose connections are present.
If problem still persist, then maybe new batteries are needed.
Sep 16, 2013 | Quantum Edge 6 Wheelchair - Used Electric...
Pride New Jazzy 600 Power Wheelchair by Mobility Logo
106 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
