Question about Vidal Sassoon Dryers
Does not start
Fan and heat was working fine. all of sudden does not turn on.
2 Suggested Answers
SOURCE: Our microwave suddenly stopped heating. The
sounds like the magnatron went out
Posted on Nov 29, 2009
My soho wasrunning fine with new waterpump and thermostat and fan switch suddenly the heat goes in the red and the fan does not switch on what could be the problem
See if electric fan is getting power when hot
Wiggle fan blade see if it has excessive play
Temp sender turns on fan
Dec 30, 2016 | Cars & Trucks
My almera tino has suddenly started to over heat even thou the water and oil levels are fine would this be a problem with the thermostat ?
doubt it --- for sudden problems check items like fan operation if electric, viscous fan hub if fitted, blocked radiator fins / corroded fins, failed cat converter blocking exhaust.
run the fault codes to check for any sensor failure.
Jan 13, 2015 | 2001 Nissan Almera Tino
Blower fan not working.
Possible speed control is open circuit or the fan motor. Check you have supply to the switch/motor.
Apr 01, 2017 | 2006 Chevrolet Malibu LT
I have a Tempstar 5000 that is about 15 yrs old and the fan motor to the outside unit will suddenly stop working and the compressor will start making a loud humming sound that does not sound too good. I...
Hello
Sounds like the condensor fan motor is going bad.If the fan stops turning or is not turning at full speed, the compressor can not give off heat to the condensor.Which will cause it to shut down on high heat.
So i would start with a new fan motor.Your local heating and cooling supply house should have these in stock.
Aug 01, 2011 | Heating & Cooling
Suddenly shutting off power sometime beeping
there was a problem with notebook overheating and it would be fixed by cleaning the cooling component ,check the heat sink and the fan. The notebook processor produces a lot of heat when the notebook is turned on you check
If the fan working fine, then check if the heatsink is clogged. In some cases you can clean the heat sink with compressed air,
Thanks,
Dec 23, 2009 | Toshiba Satellite M35X-S349 Notebook
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Pc automatic turn off
see the system temprature is cool it happen normally bcoz ho heat see your graphic card fan is working fine and it is not generating more heat. bye
Sep 12, 2007 | Acer AL1916W 19" LCD Monitor
Dryers Logo
24 people viewed this question
Top Vidal Sassoon Dryers Experts
Dan Webster
Dan Webster
Are you a Vidal Sassoon Dryer Expert? Answer questions, earn points and help others
