Question about Garden
John Deere x700 keeps blow the switched power circuit fuse
The tractor was not starting so I notice a fuse was blown 15amp switched power circuit. Put new on in it started then shut back off,put another fuse stated then blew out again
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Sounds like you might have a Short circuit. Somewhere a wire with the insulation rubbed off.
Posted on Jan 05, 2014
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
  • 3600 Answers
SOURCE: John Deere hydro 185 When I try to start
You have a bad disk in the starter solenoid pull the starter and go to a shop and buy a new solenoid or flip the disk in the solenoid and sand the two contacts so that it will make contact.
Posted on Jun 12, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
  • 17 Answers
SOURCE: 1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Posted on Nov 17, 2009
  • 394 Answers
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Posted on Mar 13, 2010
Where is the fusible link in a John Deere LX 255 lawnmower?
First thing to check is make sure you blade switch is in off position, brake/clutch is down and locked. There is a 20amp fuse in a fuse holder by the battery in engine compartment. Is it not turning over or not starting?
May 08, 2015 | John Deere Garden
When I turn my john deere sabre off at the key the engine shuts down, however ten seconds later the fuse blows. Also brand new safety switches are killing engine when released. Suggestions?
Somewhere, probably in the ignition switch circuit there is a short circuit - otherwise the fuse would not blow. You'll need to take a test meter to each circuit in turn to isolate the circuit and then find the short. Be logical and patient!
Apr 29, 2015 | John Deere Garden
Why would a mdl 1035 john deere tractor keep blowing the starter fuse
There is a distinct possibility that this tractor was originally equipped with a 6 volt system. If it has been upgraded to a 12 volt starter, the ignition will need to have a resistor installed to bring it back to 6 volts.
I could be all wrong on this but it's worth checking.
Mar 06, 2015 | John Deere Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
John deere 250 skid loader - purchased new in late 2001. every time i turn the switch to start the engine, it blows the fuse.
Apparently you have a short in the starting circuit. I would try disconnecting the start wire from the solenoid, and see if it still blows fuse. If it does it's in the control circuit. If not it's the starter solenoid.
There should be an operator present switch under the seat, that sometimes short out from an accumulation of dirt and debris that get moist.There is also a neutral safety switch and/or relays.
Oct 17, 2010 | John Deere 4020 Gas & Diesel Tractor...
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
