Question about HP DeskJet 1280 InkJet Printer
Does not switch on
My Hp Deskjet does not switch on. Once a press the power button the light remains on for about a second and thurns off. Is this a problem with the power supply?
My Hp Deskjet does not switch on. Once a press the power button the light remains on for about a second and thurns off . Is this a problem with the power supply what should i do plz help me
Posted on Jun 21, 2009
    Scholar:
  • 191 Answers
Click Here and follow the instructions to resolve the issue.
Note : Make sure that the printer is connected to wal outlet and no surge protector is used in between.
Posted on May 25, 2009
HP Deskjet 1280 Does not Switch On - only flashes the ON light for One second
you should reset the printer .
press resume button 3 second. release the resume button .May be your printer ready.
Feb 27, 2014 | HP DeskJet 1280 InkJet Printer
Is not working more
Switch the printer off.
Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
Open and close the lid of HP printer once. The light will start blinking.
Press the green button. Your HP toner cartridge chip will be reset.
Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
Need to perfrom nvram init on HP 4250
To initialize NVRAM, turn the printer power off. Remove any installed accessories (for example, a stapler/stacker). Turn the printer power on, and then hold down (SELECT button) when the memory count begins. Continue holding down until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds. Press (UP ARROW button). Press the PAUSE/RESUME button (LJ 4200/4300) or the MENU button (LJ 4250/4350). The display should show SKIP DISK LOAD. Press (UP ARROW button) until NVRAM INIT is highlighted. Press (SELECT button) the printer initializes NVRAM and then continues its power-on sequence.
Nov 07, 2012 | HP Laserjet 4250dn Network Laser Printer...
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
The scan function won't work on my HP Deskjet F4280. When I press the scan button, all that happens is the light on the power button starts flashing. Any assistance would be much appreciated.
the scan function won\'t work on my HP Deskjet F4280. When I press the scan button, all that happens is the light on the power button starts flashing. Any assistance would be much appreciated
Dec 03, 2010 | HP DeskJet F4280 All In One Printer InkJet
I have an a hp 1220c, When I plug it in and press the power button, the green light comes on for a second and then it turns off. the printer will not start up.
try removing the power cable then keep the power button pressed while the power button is pressed plug the cable back and don't release the button for 5 seconds
then try
Oct 17, 2010 | HP DeskJet 1220c InkJet Printer
My power light is flashing on my HP Deskjet 6540 printer what do I do?
jst turn off the printer and unplugg the printer from the computer and with the printer disconnected press and hold the power button of the printer for 20-30 seconds and connect it once again adn turn it on and check.
Jun 10, 2010 | HP DeskJet 6540 InkJet Printer
My computer is saying that mt hp deskjet 380 is
You can try following steps.
1. Refresh the Spooler.
To refresh the spooler, Go to Start, and in start search box or Run, type services.msc and press enter.
Now Remove the USB cable from the back of the printer.
Now on Services window, search for Print Spooler.
once found,
Make a right click on it and select Stop
Then Again make a right click on it and select start.
Perform the steps Stop---start 3 times.
Once done, close the services window.
Then steps to be done on the printer.
Press the Power button for 30 seconds while the Power cable remains out.
Then insert the Power cable. And power ON the printer, if it does not Turn ON automatically.
If the issue still persists, please post back.
Apr 28, 2010 | HP DeskJet F380 All-In-One Printer
Hp deskjet 3325 light flashing have turned device
no problems
:just go ahead and take out the power cable when the printer is still on
:nw press and hold the power button fr 30 seconds
;while holding the power button,plug back the power cable
:nw u will be able to work well
Jun 28, 2009 | HP DeskJet 3325 InkJet Printer
Help?
Press & Hold the Power Button Down and without releasing the power button Press the Down Arrow Button 4 times and release both buttons..
OR
Press & Hold the Power Button Down and without releasing the power button Press the X mark Button once and release both buttons..
Jul 11, 2008 | HP DeskJet 5650 InkJet Printer
HP DeskJet 1280 InkJet Printer Logo
237 people viewed this question
Seeker5211
Seeker5211
