Lost the original stand. i need a replacement
SOURCE: Panasonic Viera TH-42PV30 No picture & Stand-by light flashes 4 t
I would guess a power board failure. The blinking light is an error code.
SOURCE: Panasonic Viera TH-37PX70 Pedestal Stand
i need the instrucation how to install the pedestal stand
SOURCE: i have a plasma panasonic viera TH-42PV60A stand
Not power supply,it the backlight video board it dead.
Testimonial: "cool thanks alot"
SOURCE: Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
SOURCE: The Swivel Mount TV Stand
There are different types of stands as well as the screws vary. It is by the exact type of stand we can provide a screw size.
Another solution is for you to try to reach the dealer that supplied the TV stand to you, so as to get the exact screws that came with the stand.
Take care and good luck
