Question about Refrigerators
SOURCE: How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
This should help!
Brad
Posted on May 25, 2009
SOURCE: fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Posted on Aug 01, 2009
SOURCE: water dispenser line leaking at bottom of freezer
if you have enough room left you can just cut out the hole and go to any hardware store and pick up a water line coupler and repair it....if it is too short or broke up inside the door then you need to remove the water/ice dispenser and pull the line through and run the new one down the track.
Posted on Oct 03, 2009
SOURCE: The top hinge of my neff integrated fridge freezer has broken.
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
Posted on Jun 12, 2010
SOURCE: Both the freezer and fridge
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Posted on May 04, 2011
Nov 30, 2015 | Hotpoint Refrigerators
Oct 06, 2014 | Refrigerators
Apr 06, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Oct 03, 2010 | Freezers
Aug 10, 2010 | Refrigerators
Apr 18, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Mar 25, 2010 | Refrigerators
Apr 20, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
May 12, 2017 | Refrigerators
Apr 26, 2018 | Refrigerators
26 people viewed this question
