Question about HP PSC 1315 All-In-One InkJet Printer
Will not print
When i press print in a document, it just queues and does not print any suggestions Big Tel
  • terry_ingram May 25, 2009
    Many thanks worked a treat
    Big Tel
  • 85 Answers
FIrst delete the que. Make sure that the printer is the default printer under Printer/Faxes
This can found under the Start button or in control panel.
If it is default then use ctrl/alt/del to bring up the task manager and close off spooler.exe or spool.exe and reboot pc. Then try to print again.
Posted on May 25, 2009
Canon mx922 not printing word document from PC. Puts it into queue
How To Fix It - The fix is simple. You need to clear the print queue manually so that all the print jobs currently in the queue are deleted properly - once the queue is empty you should then be able to print new documents without problems. We will show you how below, depending on whether you use XP or Vista/7:
1. XP - click 'Start' then click 'Run' and in the Run window type CMD then press 'OK' - this opens a Command Prompt window. Now skip to Step 3.
2. Vista/7 - click 'Start' and type Command in the search box. Right click on the 'Command Prompt' result in the search results above it and select 'Run As Administrator' - this opens a Command Prompt window.
3. All version of Windows - in the Command Prompt window (these commands are also shown in the picture below):
4. Type net stop spooler then press the Enter key.
5. Type del %windir%\system32\spool\printers\*.* /q then press the Enter key (Note: the only spaces in this command are a single space between del and %, and a single space between * and /q)
6. Type net start spooler then press the Enter key.
7. Type exit then press the Enter key to exit the Command Prompt window.
Fixing the print queue
This should have cleared the print queue (i.e. all print jobs have been deleted) and you can now submit new jobs for printing
What Do These Commands Do?
The Command Prompt is a throwback to the pre-Windows days of Microsoft DOS but is still a useful way to type and enter system commands. The print Spooler is basically the print 'queue' - we need to Stop it running before we can Delete documents stuck in it.
The Del command deletes everything currently held in the print queue, including the 'stuck' document(s). We then have to Start the Spooler (print queue) up again so that it can accept new print job requests in future.
What If It Keeps Happening?
If the problem only occurs occasionally it is likely just due to an incompatibility with the actual data being printed ( a webpage that has unusual fonts or some other format that the printer is unable to convert into printed output - run the above fix to resolve it.)
However, if you find that almost all documents keep getting stuck in the print queue then Microsoft's answer is that it is an issue with your printer drivers (software) - one solution may be to download and update new printer drivers from the manufacturer. You could also try the Microsoft automatic Fix It for printers . This will repeat our fix above but may also flag up/fix any different Windows errors that stop printing.
Other causes may include a misconfigured printer e.g. network printing to an IP address that doesn't exist uninstalling and reinstalling the printer software from scratch should fix this.
Aug 19, 2017 | Canon Office Equipment & Supplies
Print queue stops document and will not resume
Clearing the Print Queue in Windows:
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
Cancel All Documents
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
Goodluck,
Please don't forget to rate the solution.
Apr 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
I have a Xerox Phaser 3250 printer. I went to print one page of a 1500 document and it got the message to print all of the pages. How do I cancel the printing? Help!!!
Quickly try to press cancel on the printer and then turn it off. Then Open the print queue and right click on the document and select "cancel" you may need to do this a number of times, and if you can't get it out of the queue, reboot the computer and delete it then if it is still in the queue.
Sep 30, 2010 | Xerox Office Equipment & Supplies
My printer is on and connected and my computer recognizes it. I selected it when I printed and it says "1 document in queue" but it won't print. How do I fix this?
Delete the document in queue, press Ctrl+Alt+delete at the same time and select 'Task Manager'. If the Print Queue is still appears in 'Applications' select and stop it. Turn off printer and Restart P.C., when P.C. is ready turn on the Printer fingers crossed Print Queue is no longer there. You should be able to carry on printing.
Thumbs up please if this works for you, thanks
Aug 24, 2010 | HP PhotoSmart C4180 All-in-One Color...
HP c6180 - Won't Print Documents Unless PC is Restarted
Go into the printer settings and set it to print dirctly to the printer.
Aug 21, 2009 | Office Equipment & Supplies
Document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
May 27, 2009 | Office Equipment & Supplies
Document stays in queue
You may want to update your driver.
Mar 30, 2009 | HP Deskjet F335 All-In-One InkJet Printer
I want to print new page of printing printer keeps churning out prvious printing instrctions i am 78yrs old still learning
What you need to do is clear out the printing "QUEUE".
The printer is one of the slowest devices in a computer system. If you had to wait for it to print your document before you could resume writing, you would quickly go back to using a typewriter. To eliminate the delay, Windows reserves a portion of memory for something called a “print queue” (or spooler). The queue works on a first-in first-out basis. You can continue to use the computer and send jobs to the spooler as it feeds a steady stream of data to the printer.
Print queues are nice, except when something happens in the printer to cause it to stop functioning. Sometimes it is just a paper jam and sometimes it is a bit more serious. If you need to cancel the jobs in the print queue, you can simply double-click the printer icon (in the system tray down by the clock) and open the print queue. Depending upon the length of your document and how many documents are waiting to print, the printer icon may appear briefly or for a sustained period. (Note: This would be a good time to remove the paper from the printer before continuing.) If the icon is not there, you can manually open the queue.
This should solve your problem, Let me know how it works for you..
~~Jastababe~~
Nov 19, 2008 | Lexmark Office Equipment & Supplies
Unable to Cancel Documents in a Print Run
if you want to stop a print run simply press the stop button on the printer
next go to the control panel and get to the add a printer section
click on the printer and open up see what is printing
highlight all in the print queue and delete it there no print queue , nothing to print
to be sure and not waste paper remove all but 1 sheet and press the start button
keep using that paper until what is spooled in the printer memory has been used
Mar 24, 2017 | Canon BJC 4400 InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
168 people viewed this question
Seeker5211
Seeker5211
