Question about Panasonic Viera TCP50U50 50-inch Plasma TV
I can't turn off the described video or SAP - Panasonic Viera TCP50U50 50-inch Plasma TV
How to turn off sap
SAP = Separate Audio Program, at least for one explanation. What kind of equipment are you trying to disable SAP in?
Apr 24, 2017 | Televison & Video
On CBS channel in HD when a show says available in SAP it only broadcast in that. How can I turn that off?
The second audio program (SAP) is enabled/disabled as part of initial set up. Return to that procedure and disable SAP.
Jan 15, 2017 | Televison & Video
Sonehow turned on audio description want to turn it off PLEASE Help
You have the second audio program (SAP) enabled. Return to the initial set up procedure and disable it.
Dec 11, 2016 | LG Televison & Video
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
Turn off sap mode tv
Try repeating the initial setup procedure to deselect it
May 23, 2013 | Insignia NS-LDVD26Q-10A 26 in. HD-Ready...
Turn off SAP on my vizio
Vizio TV's go to menu then settings select tuner then Digital MTS select 1/2 English. This should solve the problem.
Jul 19, 2012 | Vizio Televison & Video
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
Background voice, 27 inch "truflat" 2005 model
What you're hearing is the descriptive audio track included on many DVDs for vision-impaired viewers. Does this happen when you're watching regular TV or just with DVDs? If it happens with regular TV, do you have a cable box?
Regular broadcasting sometimes uses SAP (second audio program) to send additional audio, and this descriptive audio may be the SAP channel on some programs. Check your TV's audio settings to make sure you don't have SAP turned on. There may also be settings for SAP in your cable box as well, so check there too.
When playing a DVD, descriptive audio is usually an alternate audio track. Check your DVD player setting to make sure you've selected normal audio for playback.
Apr 04, 2009 | RCA TruFlat 27F520T 27" TV
Panasonic Viera TCP50U50 50-inch Plasma TV Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
