Magnavox msd804 cd door wont open
2005 jeep grand cherokee 6 disc cd changer wont take disc cd door wont open
time to up grade
or go broke fixing old system.
retire it.
get a media head, and use USB flash mem stick.
DISCs are dead tech, (rip yours to MP3 and move on,, really)
or WAV if you are super HD audiofile.
Apr 08, 2015 | 2005 Jeep Grand Cherokee
My cd drive disc door wont open on my Toshiba widows 8 Laptop to burn cds
Look at the front of the unit, there should be a small hole in the door cover, straighten a paperclip and push in there to manually open the door.
Feb 27, 2015 | Toshiba Satellite Computers & Internet
My Marantz CD 53 CDplayer door is not opening. what is the solution
You probably have a broken belt on the cd tray so it's neither open or closed, if the laser's ok thats why it wont play
Mar 31, 2014 | Marantz Audio Players & Recorders
Crossly turntable/cd tape player
If there's a small hole in the front of the door anywhere, push a paperclip in there to release the door.
Mar 04, 2014 | Slide-Co Sliding Glass Patio Door Latch...
Cd rom door wont open
Do you see blinking light on your CD Drive. If not, you may need to check you power supply to CD Drive.
If yes, may be door looks jam, opening up once may remove any dust to smooth it out again. To open up there is small pin hole on cd drive, generally on the right side, use needle and press it through the pin hole, it will eject the CD Door and you can pull it out completely.
May 13, 2010 | Computers & Internet
Dosent reconize new cd and wont record
es el lector que no quiere trabajar lo que tiene que hacer es cambiar de lector o optico
Aug 25, 2009 | Classic Electronics CDR201 CD Recorder
Door to load cd's wont open or close without help.
hello i have had the same problem with my 5 cd changer,i way i solved this was to turn the player top slide down then do this care fully ,shake it gently and see if a cd came out of it, groove sit in the player.if you hear a rattle than there is a stray cd in the device. you have got to shake the cd to the front of the cd dawer to take it out with a thin ruler or a butter knife but be care ful with the knife preess on the open button wale trying to slide the butter knife between the stuck cd and the inside of the cd sit cation be care.
Apr 25, 2009 | Audio Players & Recorders
Hi...
I use a place called
www.studiosoundelectronics.com
or
matelectronics.com
Studiosound will even tell you how to measure your belt if you need to
Godspeed,
Scott
Dec 16, 2008 | Yamaha CDC-845 5-Disc CD Changer
Broken Magnavox 5 disc changer
old is always gold... just follow some tips as i say... open the player with the door ejected clean the lens wit the dry cloth and clean the dust particles in it especially near the rubber belt connected to the dc motor... after that try to play cds it will play...
Feb 06, 2008 | Audio Players & Recorders
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
