Question about Craftsman Garden
17 hp craftsman rider will not start
Pour gas in carb and it will start till gas is gone then dies and have to do all over again.
    President:
  • 2,559 Answers
The carb needs to be taken apart and cleaned.
Posted on May 20, 2009
  • 1,906 Answers
Replace your fuel filter
Craftsman rider. Only starts when I add gas to carb. Runs about 10 sec than dies. I have check all fuel lines cleaned carb. Fuel pump works. Not sure we're to go next
Sounds liek gum deposits have clogged the carb. Remove, disassemble, and soak in carb cleaner. Then blow out all passages with compressed air. Should work after that.
Jul 15, 2014 | Garden
My craftsman 18.5 HP OHV will not start
first see if the fuel pump is working remove the hose from the carb and crank it over if fuel sprays out it works the see if you have power to the solenoid to the bottom of the carb if so remove the solenoid and put power to the wire and a ground if it is stuck carb cleaner can free it up if it moves remove the bowl from the carb and see if fuel is getting inside the carb a bad needle vale would stop it from getting threw
Aug 18, 2012 | Craftsman 18.5 HP 42"
Craftman 917.270.711
check to see if the oil smells like gas the needle valve in the carb doesn't seat and gas drains into the engine the oil gets thin and burns it fast
May 30, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lt1000 20hp. briggs electrics on carb it will run when you pour i
Check fuel lines for clogging.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 550 brand new mower wont start
SONDS LIKE A FULE PROBLEM IT MAY NEED THE CARB CLEAND MAY HAVE BAD GAS
Oct 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No Gas
Most probably the carb restricted by varnish, trash or rust. Need to clean carb. You'll probably see the problem when you remove the bowl.
Jul 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Won't start after killing the motor
May need more info. Check for a seat switch to have came unpluged (wiring) this is a safty thing. You have to have your foot on the brake as you sit in the seat to get it to crank. repost if you need more help.
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman GT5000 W/22hp B+S surges and dies when warm
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
Apr 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lawn mower dies
Find the fuel air mixture screw and while the mower is running turn so mower almost stops then turn them back till the moter is running smoother.Give it some throtle to see & hear how it is running
Nov 02, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
93 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
