Question about Jenn-Air JMC8130DD Microwave Oven
How to clean between the oven door glass on a jenn-air model jjw9530008
MicrowaveSvc
  • 9047 Answers
SOURCE: replacing outer glass and stainless steel door on my jenn-air microwave oven
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Sep 01, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: how to clean in between glass on oven door
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
I would recommend looking at those exploded views.
Posted on Sep 26, 2008
  • 52 Answers
SOURCE: The Jenn-air microwave (built-in)
your jenn-air wring problem ok
Posted on Oct 05, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Can the Jenn-AIr microwave oven
If your oven used a more normal rotating turntable you might be able to get away with a replacement other than the original. But this oven has a screwy arrangement where the oblong tray moves back and forth in the cooking cavity instead of turning.
In most ovens, the turntable motor drives a coupling which in turn engages fitted spots in the bottom of the glass tray, and the tray goes round and round. In your model, a projection on the coupling fits into a slot on the tray bottom to convert the motor rotation into back and forth motion, and it only works on the original tray. You might find a tray that will fit into the oven, but it won't turn. You would need to stop the oven, open the door, and manually rotate the food occasionally during cooking. You would also lose some capacity since the round tray wouldn't hold as much as the original oblong one.
The original tray part number is 53001532. Here's one source for the original. If they still have them, it's a good price and would be the best way to keep the oven running as designed.
Posted on Jul 03, 2011
caroldon
  • 17129 Answers
SOURCE: The latch that opens the door to my Jenn-Air model
If the point of damage can be glued together with good bonding and further re-enforcement , it can be strong to withstand pressure.
So remove the assembly to try this out before you think there is no way out but to replace with the handle assembly from the service center.
The other option is to get one from a scrapped set.
Posted on Oct 04, 2011
Help need replace glass panel in pvc
This door is radius and would be difficult to replace. Repair clinic claims the part is due in at the end of this month, I wish you luck on your search. I have not seen someone make this correctly as the metal supports at the bottom are attached to the glass and the stainless steel outer panel is just a panel stuck to glass.
Good luck
Feb 05, 2014 | Jenn-Air Microwave Ovens
Clean inside glass door jenn-air jmc8130dd
follow your instruction manual, download from www.fitness.manualsonline.com or www. retrevo.com
God bless you
Dec 09, 2013 | Jenn-Air JMC8130DD Microwave Oven
Hi, i have a dirty window , have cleaned both sides without touching it. think its between the glass and the liner. can' find my manual. can i take the bake of the door glass off some way to clean...
Hello, Thank You for using FixYa. I will be helping you today. It is hard to take apart without breaking it! It is held together with all plastic clips and they break! But you can by putting a putty knife in the inside door seam all the way around and pry the clips down to pop the door apart.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Jenn-Air JMV8196 Microwave Oven
Handle broke off Microwave oven door can I repair? How can I access mounting screws? Where can I find parts?
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If the model number is correct, the part numbers for a door handle replacement is 56001139 and 56001136. There are two pieces with the door handle on this model oven. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you.
Dec 29, 2009 | Jenn-Air JMV8000 Microwave Oven
Cooling Fan stays on until the door is open
May be a sensor or thermostat for the fan thats faulty therefore it runs all the time.
Sep 16, 2009 | Jenn-Air JMV8000 Microwave Oven
How to clean in between glass on oven door
Sep 19, 2008 | Jenn-Air JMC8130DD Microwave Oven
Replacing outer glass and stainless steel door on my jenn-air microwave oven
Aug 30, 2008 | Jenn-Air JMC8130DD Microwave Oven
Jenn-Air Microwave turntable not working, microwave works
It's probably a cracked coupler or a weak, slipping motor.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 03, 2007 | Jenn-Air JMC8130DD Microwave Oven
Jenn-Air JMC8130DD Microwave Oven Logo
22 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Dennis Boxerman
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
