Will start at first then once warmed up it will not start again. remove the top of the air cleaner and it starts fine.
Yes
I'm sorry I see that your generator is Nat gas; is it carbreted?
Adjust your carburetor jet screws all the way out remember the number of turns (so you can return them to the old setting if needed) then: count the turns clockwise in until the screws bottom then: counting the turns back them out: counterclockwise 1/2 as many turns eachas it took to bottom them. this is the "normal adjustment and, the engine should start unless the floats or, the gas blend regulator are not allowing fuel in. LP gas can and, does easily vaporlock do to heat so; also check the fuel line/filter system
Those are only the idle set screws are there any red or, blue plastic covers at the carburetor base...Do you have a name part# for the carburetor I can look up?
yes it is
There are no screws on the carburetor however there is throttle arm on the inner side with adjustment screws.
No sorry no part number, I will get it im heading back to the house tomorrow. There are no blue or red covers on the carb.
