Question about Electrolux Floor Pro Vacuum
How to put on wool buffers - Electrolux Floor Pro Vacuum
How can I get marks off the sole plate?
Steel wool or scotchbrite pads.
Apr 07, 2017 | Vacuums
Makita buffer clicking, sparking and burn smell, power loss upon immediate use
it is a armature problem common to makita products
replacing one armature with a new one does not solve the problem as the fault is a design fault
probably armature not wired heavy enough for continuous running
consider replacing it with a better brand that enables continuous operation
Nov 24, 2016 | Makita Vacuums
What is the best way to clean a fresh blood stain from a wool carpet?
Cold water on a clean cloth, blot with damp cloth, then with dry cloth, repeat, repeat, repeat until you do not see any red coming out. If you have a carpet cleaner flush it with lots of cold water sucking it up with your carper cleaner or extractor. A good professional carpet cleaner can prevent your spot from becoming a stain. Often you can use enzyme cleaners to remove blood but NOT on wool carpets.
Apr 07, 2016 | Vacuums
How do i clean a handmade wool rug that is stained and really dirty
These are usually quite durable. I use a fairly stiff brush with mild soap and water. If the carpet is good quality, you can rinse with a garden hose or even a pressure washer . Hang over a bathtub or outdoors to dry. Drying will take two or three days, but do not leave out in the sun longer than that. Professional cleaning is also available if you wish.
Sep 22, 2014 | Royal Palace 33"x53" Flowers & Butterflies...
The bellt is smoking
check the shaft the belt is driven with for black residue from the belt===residue will cause the belt to slip and also can cause from friction smoke there===clean completely with alcohol or very, very fine steel wool.
Nov 07, 2012 | Vacuums
The "hand" run by battery
You have to take it all apart and clean the gears and shaft with keroseen on a rag. Use steel wool to take the rust off the shafts and gears and see if the motor will spin without the gears attached to it. If it does not that has to be taken apart and cleaned. When putting it all together use a light grease or vasoline and put a little on the gears and shafts. Put a little on the motor shaft but make sure you do not get it on the comutator where the brushes ride on the motor.
Mar 11, 2011 | Vacuums
Is the Dyson pulling carpet fibers, not dirt ?
You need to shut the brush roll off. It is ruining your rugs, the dyson has a very aggressive roller and can hurt some types of rugs and carpets.
Aug 17, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Electrolux Floor Pro Vacuum Logo
15 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
