Sony wega hdmi
I have an older Sony Wega TV which only has one HDMI port. I believe the port is loose, so when ever the wire is moved a bit, I loose the connection and get a blank screen with no sound. This has happened several times and I've fixed it each time. I just don't remember what I did. I'd unplug everything, turn everything off, and wait before setting it all up and it coming back. Is there a better way to reset it. Sometimes I can get it back, while other times it takes hours. Right now its going on 12.
SOURCE: sony kdl-40s2000
I have had an extremely similar problem with my Comcast Motorola DVR and Sony Bravia with HDMI connection. For months I would lose picture/keep sound when changing from a non-HD to an HD channel. The solution that I found is that there is a setting in the cable box setup that will likely fix your issue. Turn off your cable box leaving the TV on. Quickly press the Menu button on your remote to get into the Box setup. Make sure that 4:3 Override is set to "Off" instead of 480i. I believe this will solve your problem.
Posted on Jan 31, 2007
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Posted on Jul 09, 2008
  • 10594 Answers
SOURCE: Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Posted on Aug 17, 2008
SOURCE: JVC HD-70FH96 both HDMI problems
Have you been using a flashlight behind the TV. These TV's have a sensor that shuts off the unit when the rear cover is removed (by sensing light). You may have tripped this. I think you can fix this in the service menu somehow but I can't remember.
Posted on Oct 10, 2008
  • 5138 Answers
SOURCE: TV shuts down and blinks red 6 times
Lamp or Fan is going bad.Take lamp out see if it looks good if so listen/watch to see if Fan keeps runningwhen turned on if Fan stops running ,Lamp and power will not come on.!
Posted on Dec 18, 2008
Can i use a firestick with my sony wega kdf-e42a10
Fire TV Stick connections....
1 Connect USB cable into fireTV stick, and plug in power adapter. ...
2 Amazon fireTV stick and power adapter. ...
Connect fireTV stick to HDMI port via HDMI extender.
3 Amazon fireTV stick connected via HDMI EXTENDER CABLE TO Monitor HDMI port. ...
4 Turn on TV and select HDMI port
Feb 04, 2018 | Sony Televison & Video
HDMI connection off and on
it`s better to bring it to nearest electronic workshop in your area,qualified technicians can solder and knows how to fix it better.
Jan 01, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega tv hdmi not responding to xbox one
Is the Xbox one not picking up the tv if not try an HDMI cable. They mostly cost $15
Dec 30, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do I fix an HDMI input that has stopped working
This sometimes happens on my Samsung tv. With the tv switched on try unplugging the tv from the mains supply and leave for 3 minutes then plug back in and try. I hope this helps.
Nov 16, 2013 | Sony Grand WEGA KDF-55XS955 55" Rear...
Hello, have a Sony Trinitron KV-36FV27 and I want to know if it has hdmi so I can connect it to the lap top
I believe it does. It will say HDMI 720p and the connector port is very distinct. You can't miss it..
Dec 30, 2012 | Sony FD Trinitron WEGA KV-36FV27 36" TV
My sony WEGA LCD Colour TV has no HDMI port?
Google the Model number for Specs-----HDMI until a few years ago was not all that common---
May 13, 2012 | Sony Televison & Video
I have a sony wega KDF42WE655 TV(42 inch). It has a HDMI port I recently bought a PS3 and hooked it up to the TV. With the HDMI port connected I do not get any picture or sound. Attempts of rebooting...
There is a separate IC on the main board that does nothing but process the HDMI signal, basically if your using the cable, AVI or any other input other than HDMI and chances are that is bad, it can be replaced if you have a lot of electronic experience, its a $3 chip but its not easy to replace..I would replace the main board if you can find one, sometimes main boards are hard to find..below is a link to the service manual.
Sony KDF 42WE655 Service Manual
Nov 23, 2017 | Sony Grand WEGA KDF-42WE655 42" Rear...
Ps3 sony grand wega (4 yrs old)
Press the input button on the tv itself to select the proper input you desire.
Dec 27, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony trinitron KV-30HS420 HDMI
Yes. As long as your PC has an HDMI port as well (or at least a DVI port and a DVI-to-HMDI converter dongle).
Jul 10, 2008 | Sony FD Trinitron WEGA KV-30HS420 30" TV
HDMI function works with all those components who have HDMI port in it. I dont know I made my point clear or not.
May 27, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
