I have a 1GB SanDisk Cruzer and the tip (the part that sticks into the USB port) broke off. I have information on the disk that I really need (my dissertation). Is there any way to recover it?
Hello, Try to format the mp3 player. Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management> Try to format it with fat files system. hope this help you Regards uttam
all you do is plug it in one of the usb ports on the computer and on the desktop a menu will pop up and select to view files or select it from the computer section and you can then drag files to the drive and put them there and visa versa hope this information was helpful :)
A SanDisk Cruzer Mini is a memory stick, like a modern floppy disk. Plug it into a USB port (a thin rectangular hole) - it may be at the back of your computer. Your computer should then recognise it and you can copy files onto it.
hi turn off your pc put the card into the usb then turn on your pc let the pc find the drives for it and load on if this dose not work try the same in another usb port ok
if it works you must format the 1 gig stick befor you use it
ok hope this helps
I'm guessing you are using a Mac, so you will need a friend's computer with Windows XP or later. Go here
for the U3 Launchpad Removal Tool, or Google 'sandisk u3 removal'. The
CD image is a hidden partition used by the U3 LaunchPad.
