Question about LG 42LD550 42 in. TV
LG 42LD550-UB TV stays in blinking red light
I have an LG 42LD550-UB model. When I started the TV one morning, I thought I heard a small "frizzle" in the back, and the TV has not been working since then. When I power it on (either via remote or the panel), the red light at bottom of the screen turns RED and stays blinking red - no picture or sound. After this, I am unable to switch it off either via remote or panel. Only way to get the RED blinking light off is to disconnect power supply from the wall. When TV is powered on and the RED light is blinking, nothing happens if I change the channel, or volume, or INPUT or menu buttons. I have opened the back panel and do not see any bulged capacitors. What could be wrong? Are there any fuses that could have blown, or is it power supply board that needs to be replaced in its entirety? Any help to diagnose and fix would be very helpful. Thanks SU
SOURCE: LG RZ-23LZ40 no Picture
Thanks Jaime867
Best send repair manual.
I have pics to show / identify problem but I cannot attach to my reply. Parts defective are: 4532M x 2 (UC2 & 3), diode next to diode RC22 & cap C35 and IC6 (cannot see part number). Board number is YPNL-M007B r1.0, also recognized L.G. Phillips part number: LC230W01-A2
My hands are not as steady as years ago to do surface mount solerering but my wife can as she has done this before being electronic equipment assembler.
As stated before I need to find source of what I suspect is short that had blown these components.
I bet a replacement board is more expencive than a new LCD TV!, but I want to resolve this prob and maybe help others...LG too.
Thanks Heaps Jaime867!
Cugar63
Posted on May 25, 2008
  • 298 Answers
SOURCE: Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Posted on Dec 29, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: No Picture, No Sound
You can try troubleshooting the power supply section, which actually the only thing you can fix in these tv. check for leaking capacitors, bad semiconductors, such as diodes, transistors, which may be overheating and causing a short. troubleshooting electronic circuits is a pain unless you know a little about it. You may want to learn a bit about electronic first before you actually start taking parts out of a circuit.
Posted on Aug 04, 2009
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Posted on Mar 21, 2010
SOURCE: Lg 42lc7d turns on to blank screen doesnt respond to any request
I need sreen for LG 4LC7D-UB because the screen is damaged
Posted on Mar 21, 2011
I have problem with LG TV 42LD550. After power up I see just first screen "Live Good" with no time on it and that all. Remote doesn't work, buttons on TV don't work. What can I do?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 20, 2014 | LG 42LD550 42 in. TV
Does this tv need a dongle to connect wireless?
http://www.lg.com/us/tvs/lg-42LD550-lcd-tv Read the specs. You'll need the adapter which is sold seperately.
Oct 09, 2014 | LG 42LD550 42 in. TV
42LD550 hdmi no signal
hi have you tried factory reset if this don't work you may have to go into service menu and reset the tv back to when you first brought it, to do this, there's 2 sequences you have to do 1 press hold menu on the remote and menu on the tv for about 10 second , if this don't work try this one, press and hold ok on the remote and ok on the tv for about 10 seconds you see a menu pop up scroll to reset but you have to retune the tv in again hope it helps
regards
shaun
Jan 04, 2014 | LG 42LD550 42 in. TV
LG 42LD550 LCD - Internet connection problem
After the network is connected to the TV, you have to go into the TV’s network menu to complete the setup process.
If you look in your owner’s manual starting on page #55-#57, you can read the direction to walk you through the wired network setup process.
It should be very easy to setup as long as your router has the DHCP turned on. That allows the TV to automatically assign it an IP address on your network.
If the DHCP is not turned on in your router, then the TV’s IP will have to manually entered by you.
May 20, 2010 | LG 42LD550 42 in. TV
My TV won't turn on
Unplug it plug it back make sure it does't have a main switch on it at the bottom. If your a novice call a lg service center.
Apr 25, 2009 | LG 50PC3D 50 in. Plasma Television
Cuts off
Most likely the power supply board.
Lie the tv down on a bed and unscrew the back. Its only about 9 screws around the edge and look at the power board, on the left, see if theres any burn marks.
I have a brand new board I bought the other day for the same issue but before I replaced it, stupidly, I checked with LG and turns out mine is still under warranty so I'm stuck with a new board.
Let me know if you want it. I'll match any price you can find online.
Mar 20, 2009 | LG 42LC7D-UB Television
Mar 16, 2009 | LG 42LC7D-UB Television
LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Jul 28, 2008 | LG 42LC7D-UB Television
LG 42LD550 42 in. TV Logo
540 people viewed this question
Computer Repairing
Computer Repairing
