Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
My gas was turned off for 4 days. after being turned back on the pilot will light and the burner fires up but shuts of in 10 minutes
Changed thermocouple, but it still shuts down
    Problem Solver:
  • 16 Answers
If heater has a sealed front door the air intake filter is probably clogged. Remove the door and vacuum out all the dust and debris in the inside. Then use an air compressor to blow down thru the filter and force out any dust caught in the underside of the filter. Reinstall assemble heater and relite. If problem continues replace the gas control. If unit does not have sealed door just replace the gas control
Posted on Jan 15, 2014
4 Suggested Answers
  • 4 Answers
SOURCE: intermittent pilot and burner
sounds like ur gas valve solanoide is done . depending on what type and age it is , it will have either manual or electronic ignition . one last shot wourth trying iis the jet may be slightly blocked, remove it and blow it out with a compressed air line do not try cleaning it with a wire or similar. put it back together and try firing it up. good luck .ps what part of the world do u live because these arent a common house hold appliance in ireland they are only used in commerical building,s over here.
Posted on May 01, 2009
  • 16 Answers
SOURCE: i have replaced the control valve and thermocouple
Thermocouple is probably not adjusted in to the pilot flame correctly, readjust and try again, if that does not work replace the thermocouple, not all brand new thermocouples are good right out of the bag
Posted on Jul 10, 2009
  • 68 Answers
SOURCE: water heater pilot wont stay lit
try cleaning the top of the pilot light jet if you can get to with small brush then blow it clean with a compressor.
Posted on Aug 30, 2009
Any idea why my Atwood water heater will shut the main burner and the pilot light off at the same time? Sometimes runs for 20 minutes, sometimes 2. I hear a clicking sound, then they both shut off.
The thermostat shuts off the main burner.The pilot light gas is controlled by the thermocouple which the side of the pilot flame has to envelop. If the flame is too small or too far away from the flame, it shuts the gas off to the pilot. The thermocouple generates a small voltage which keeps the pilot gas open. It can over time fail itself, so look at replacing it. The thermostat sounds like it's failing too.
Apr 27, 2016 | Water Water Heaters
U can light the pilot lite,turn 2 ON it will stay lit 4 a couple of minutes then go out? If u turn the knob 2 low,med. It goes out pretty much immediately?I changed the thermocouple,blew the lines ou
Is the thermocouple secure, routed properly, no kinks, no sharp bends? Is the end of the unit properly aligned so the hottest part of the pilot flame is hitting the unit. Did you hold pilot switch in the light position for at least 30 seconds, before you set the gas valve to on? If all above OK, try this. Light the pilot using barbeque lighter once it lights keep the lighter on the t-couple for 30 seconds, then set the valve to ON and keep the lighter where it is. Once the main burner lights, remove the lighter. If the burner and pilot go off, your gas valve is bad.
Feb 17, 2015 | Rheem Richmond 75 Gal Natural Gas 6 Year...
I can get the pilot light to stay on but main gas burner won't fire up
If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
Nov 04, 2014 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Gas water heater: burner doesn't fire, replaced gas control valve
Hello,Don't worry about the rust flakes as every burner collects then and is normal.The new control should click.Please check incoming gas pressure supply 3.5"WC natural gas / 9"WC for LP.Check it at the piolt tube with a pressure dial meter,I assume the water temp now is cold.Did you change the thermocouple also as this provides the power to run the control?
Apr 22, 2010 | General Electric GE SmartWater Household...
Water heater pilot wont stay lit
Aug 30, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
Gas hot water tank, pilot light
Look inside the water heater when it is heating the water, the flame should be blue. If it has yellow tips on the flame, it needs an adjustment to the air shutter. There is a nut on this air shutter to make this adjustment. This adjusts the air gas mixture. You may first try just simply tapping on the burner lightly to loosen any debris that may have built up and vacuum it out. MAKE SURE YOU TURN OFF THE GAS BEFORE CLEANING THE BURNER!! Also, check for drafts that may be blowing out your pilot light, Furnace register or outside drafts on windy nights. Some water heaters have an automatic shut down if the water heater gets too hot, so don't have it set to its hottest setting. Most water heaters only last about 10 years or so, It could be you are ready for a new one....Joe
Dec 16, 2008 | Water Heaters
Pilot lights (not always) but gas will not flow into burner
First Clean the ignitor assembly and make sure the flame is reaching the flame sensor strongly.
You may need to replace the flame sensor.
Sep 19, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
53 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
