Question about Kenmore 44042 Front Load Washer
Spins during cycle, but doesn't fully drain and no final spin
We have owned this (Model 417.441525400) for less than 2 1/4 years.  Fine yesterday, but doesn't drain fully and no final spin.  I have to wring everything out by hand.  Any ideas before my husband rips it apart?
  • 1 more comment
  • bizzy Oct 20, 2007
    The drain pump seems to work fine.  It pumps out the water for each cycle  During the spin cycle, I can hear the pump running, but the washr is not spinning.
  • bizzy Oct 21, 2007
    The LEDs on the right flahed 4 times, and the start button flashed 3 imes.
    I tried this, and the problem still exists.  Can you tell me how to get to the main control board?
    President:
  • 878 Answers
Bizzy, as long as you are satisfied that the pump is ok, try putting it into a diag mode and see if we can come up with an error code.  First wake up the machine by pressing any button, then within 5 seconds press and hold the two greyed out buttons on the right  (pause and start cancel). As long as you hold those 2 buttons in, the error code should be flashing. Keep holding them in. Now you will have to count the times the 5 leds on the right flash. When they stop, count the times the start button flashes.  This will give you the code.  Post back here with the results and we'll see if we can come up with a code..Catriver
Posted on Oct 20, 2007
  • Ron Marek
    Ron Marek Oct 21, 2007
    bizzy,  ok,  the error that you are reading is a E43.  As long as you don't have a letter (some have digital displays) such as A,B,C etc. showing. E43 is a control problem error and the tech sheet says to replace the control board.  Before doing that, place the washer in the diagnostic mode.  Turn the dial to drain/spin. Press pause/cancel to turn off all led's. Within 5 seconds press and hold the options and pause/cancel buttons until the led's start chasing each-other.  Now each click of the dial clockwise will test a function of the washer such as hot fill, cold fill, tumble, spin, etc.  When you get to 9 clicks clockwise the error will appear again.  To clear it press and hold the options and pause/cancel buttons together for 3 seconds.  The code will be cleared.  Unplug the washer for 30 seconds and see if you are still having the same problem.  If so,  then replace the main control board.   Catriver.
  • Ron Marek
    Ron Marek Oct 22, 2007
    You will have to remove the top, Three screws in back, if it's hinged in back then there will be 2 clips in front that will have to be pushed in and the top will come up.  Im pretty sure your's will slide off toward the back.  The control board is mounted to the control panel in front.  This whole panel can be removed.  When you remove the top you will get a good idea on how it comes off. Be careful, you will have the plastic led's to contend with when removing the board.  The dial itself is keyed in so you don't want to force it or you will break it.   Just take your time and observe carefully when removing,  you should be just fine.  Catriver.
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
Spin Cycle
you can check the direct drive coupling between the motor and the transmission, if the coupling is good and not broken then you have a transmission problem
Apr 30, 2008 | Washing Machines
Kenmore 44042 Front Load Washer Logo
139 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
