Question about Nokia J Bluetooth Headset BH-806
Nokia BH 806 Bluetooth Headset doesnt turn
The first time I charged it the red indicator light flashes 3 seconds. After that nothing happens
2 Suggested Answers
SOURCE: My Nokia Bluetooth headset (
I have exactly the same problem...
Posted on Jun 07, 2011
My nokia bh503 headset not charging
Leave it plugged in for 4 hours. Yello should turn red then green when fully charged
Oct 20, 2014 | Nokia Bh-503 Bh503 Bluetooth Stereo...
When I try to couple the BH-218 to my Garmin i press the ]as in the manual but only get voive prompt on or off, the coupling mode does not seem to function.
My guess is you don't have the headset in pairing mode. The instructions below are from the instructions for the BH-218"
Before using the headset, you must pair and connect it to a compatible phone.
1. Make sure your headset is switched off and your compatible phone is on.
2. If you've never paired the headset with a device, or you've cleared the pairings,
switch the headset on.
If you've previously paired your headset with another device, press and hold the multifunction button
for 5 seconds.
Pairing mode is switched on, and a blue indicator light starts to flash quickly.
3. Within 3 minutes, switch Bluetooth on in your phone, then set it to search for
Bluetooth devices. For details, see the user guide of the phone.
4. On your phone, select the headset from the list of found devices.
5. If asked, type in the passcode 0000.
When the headset is connected to a phone, the Bluetooth indicator light flashes
slowly.
You can pair your headset with 8 phones, but you can only connect it to 2 phones at
the same time.
With some phones, you may need to make the connection separately after pairing.
Tip: Can't connect the headset to a compatible phone? Make sure that the headset
is charged, switched on, and paired with the phone.
Jul 15, 2013 | Nokia BH-218 Bluetooth Headset
I am trying to pair Nokia E63 with Bluetooth Headset BH-213 but my Nokia E63 is not able to search Bluetooth Headset device. I have already turned on Bluetooth of both devices. Please guide me.
Please follow the proper instructions given below to successfully pair your Nokia E63 with the Nokia BH-213 Bluetooth Headset.
1.Ensure that your phone is ON and headset is OFF.
2.Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly.
3.Activate the Bluetooth feature on your phone, and set it to search for Bluetooth devices.
4.Select the headset from the list of found devices.
5.Enter the passcode 0000 to pair and connect the headset to your phone.In some phones,you may need to make the connection separately after pairing.
6.When the headset is connected to your phone and is ready for use,the green indicator light flashes slowly.
However if you are having problem with the Bluetooth connectivity of your phone the most probable cause may be a malware attack.It can be solved by cleaning your phone memory by entering *#7370# on your phone and restoring the default settings when prompted.Make sure you back up your contacts to the memory card or copy it to the SIM directory.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 24, 2011 | Nokia Bluetooth-Headset BH-213 2600...
I m not able to connect my BH 208 headset to nokia E71 set
Make sure that the headset is properly charged before following the instructions below.Please follow the detailed instructions in the correct manner to successfully pair your Nokia E71 with the BH-208 Headset.
Charge the battery
The headset has an internal, non removable, rechargeable battery.Do not attempt to remove the battery from the device, as you may damage the device.
1. Connect the charger to a wall outlet.
2. Connect the charger cable to the charger connector. The red indicator light is on while charging.
It may take a while before charging
Switch the headset on or off
To switch on, press and hold the power key until the headset beeps and the green indicator light is displayed. To switch off, press and hold the power key until the headset beeps and the red indicator light is displayed briefly.
Pairing the headset
1. Ensure that your phone is switched on and the headset is switched off.
2. Press and hold the power key until the green indicator light starts to flash quickly.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the phone menu where you can view the currently paired Bluetooth devices.The headset is now ready for use.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex.
Jun 14, 2011 | Nokia BH-208 Wireless Headset
How To turn on the headset bloothoot nokia model bh212
Switch on or off
multifunction key for about 2 seconds.
The headset beeps, and the green
indicator light is displayed. The
headset tries to connect to a paired
phone.
multifunction key for about 5 seconds.
The headset beeps, and the red
indicator light is briefly displayed.
Pair the headset
1. Ensure that your phone is on and
the headset is off.
2. Press and hold the multifunction
quickly.
the phone, and set it to search for
Bluetooth devices.
found devices.
phone. In some phones, you may
headset appears in the phone menu
your phone and is ready for use, the
Mar 26, 2011 | Nokia BH-212 Bluetooth Headset
My nokia BH-215 is not pairing. The green light blinking continuously.
hello, clear setting or reset, to delete the pairing from the headset , press and hold the power key and the answer/end key (for about 5 seconds) until the red and green indicator lights start to alternate. to reset the headset if it stops functioning , even though it is charged connect the headset to charger while you press and hold the answer/end key , Ensure that your phone is on and the headset is off.press and hold the power key (for about 5 seconds until the green indicator lights start flash quickly. activate the bluetooth feature on thr phone, and set to search for bluetooth devices. select the headset from the list of found devices . enter the passcode 0000 to pair the phone. hope it works
regards
shaun
Oct 10, 2010 | Nokia Consumer Headset
How to pair up nokia bluetooth headset BH-213 with blackberry curve 8520 ?
Hi
1.Ensure that your phone is on and the headset is off. 2. Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. When the headset is connected to your phone and is ready for use, the green indicator light flashes slowly.
thank You
Aug 31, 2010 | Nokia Bluetooth-Headset BH-213 2600...
Got a New Nokia BH-106 bluetooth Headset, i'm
i purchase new Nokia bluetooth headset BH-106 and i want to connect my laptop ( Dell INsprion N5010) plzz give some advise who to connect it.
Sep 21, 2009 | Nokia BHF-2 Headset
Nokia J Bluetooth Headset BH-806 Logo
63 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
