Question about Belling DB2 Dual Fuel (Electric and Gas) Kitchen Range
Replace element rear element fan oven
2 Suggested Answers
SOURCE: oven not heating up
Easy enough job, you can access the element via the screws inside the oven compartment. Just make sure the unit is isolated at the mains. It is then simply a case of removing the screw that holds the element in and unpluging the spade crimps that connect to it. 5 minute job at the most. Maybe you can help me in return, I have the cookcentre 132wgr but no instructions do you know where I could get some???
Posted on Mar 25, 2008
Can you replace oven element, cannot see any screws in oven to remove plate to gain access
You will have to remove the oven from the housing, and then remove the rear cover of oven, and gain access to the securing screws for the element from the rear of the oven, you will see how it is fixed once you remove the outer panel of oven
Feb 23, 2011 | Candy FP855 Electric Single Oven
Main oven not heating up but fan is working on kenwood ck405 oven
Kenwood Oven not heating? How to replace a Kenwood fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 13, 2010 | Ovens
The main oven of my DY46 Hotpoint is not heating up
It will be the element that has gone, and it is easy to replace.
Remove the cover at rear of oven compartment, and you will see the fan element, just undo fixing screw,and replace element.
Feb 22, 2010 | Hotpoint DY46 Style Line Stainless Steel...
Oven not heating but fan working
Candy Oven not heating? How to replace a Candy fan oven element
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for candy element How to Repair Home Appliances
Jan 16, 2010 | Candy Ovens
The fan in my oven is blowing out cold air and while the convention oven is working- it takes a long time to heat up and doesnt cook food as well as the fan assist
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for element How to Repair Home Appliances
Dec 11, 2009 | Candy Ovens
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 | Smeg Ovens
Main fan oven does not work, conventional main oven does work
The element is where you said and yes it can be replaced without removing the oven. Remove the bacplate from inside the oven and you will see the element and fan. Remove the screws from the element and gently pull it forward then remove the 2 wires and keep hold whilst you fit the new element. Replace screws in the element refit the backplate job done.
Jul 29, 2009 | AEG U7101-4 Electric Double Oven
Hotpoint EG900X rear round heating element
If the fan is working, but there is no heat from rear element, then the element needs replacing.
Remove inner rear cover of oven, you will see the element there, remove, and replace.
Please leave a rating for my suggested solution.
Thanks.
Feb 17, 2009 | Maytag MEW6527DDS Electric Single Oven
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
No heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Jan 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
Belling DB2 Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
