Bios reset asus - Computers & Internet
Tip
Retrieve Password on ASUS Eee Pad Tablet
Looking For a Password Recovery Program to Access Your Locked ASUS Netbook? Apple's iPad 2 maybe the hottest thing on the hip-happenin' trendy tablet block, but Asus isn't that behind with its own version, currently dubbed the Eee Pad. Till April 2011, this computer has occupied a considerable market share. In this article, we will learn how to <a href="http://www.windowspasswordsrecovery.com/retrieve-asus-password.htm">retrieve ASUS EPad Password</a>. <br /> <a href="http://www.windowspasswordsrecovery.com/images/knowledge/retrieve-asus-password/asus-eee-pad-tablet-password-big.jpg"><img src="asus-eee-pad-tablet-password.jpg" /></a> What is ASUS Eee PC? Asus Eee PC is a subnotebook/netbook computer line from ASUSTeK Computer Incorporated, and a part of the Asus Eee product family. At the time of its introduction in late 2007, it was noted for its combination of a light weight, Linux operating system, solid-state drive and relatively low cost. Newer models have added the option of Windows operating system and traditional hard disk drives.<br /> The first Eee PC was a milestone in the personal computer business, launching the netbook category of small, low cost laptops. According to Asus, the name Eee derives from "the three Es," an abbreviation of its advertising slogan for the device: "Easy to learn, Easy to work, Easy to play".<br /> Some of ASUS's hot products <b>Eee Pad</b>: Eee Slate EP121, Eee Pad Transformer TF101<br /> <b>Eee PC</b>: Eee PC T91, Eee PC 1000HD<br /> <b>EeeBox PC</b>: EeeBox PC B201, EeeBox PC EB1502<br /> How to Regain Password on ASUS Eee Pad Tablet? There are 2 passwords in an EPad, a bios password, an Operation System password. We will separately discuss the 2 cases.<br /> Bios Password Bios password is setting on the bios config, we can press Del button during loading the PC to enter bios config menu, then remove the bios password. Sometimes, you don't know the bios password, look this guide: "<a href="http://www.blog.windowspasswordsrecovery.com/top-3-methods-to-crack-bios-password/">Top 3 methods to crack bios password!</a>".<br /> <b>Tips</b>: As we know, EPad uses touch screen. We could connect it with a USB keyboard to press Del button. <br /> Operation System Password We can install many OS on an ASUS tablet, for example: Linux, Unix, MAC OS, Windows. Here we discuss only windows. <b>1.</b> Download <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Ent_Trial.exe"><b>Windows Password Recovery Tool</b></a> (free trial).<br /> <b>2.</b> Install and run it.<br /> <b>3.</b> Create a password reset disk. A CD/DVD disk, or a USB Flash Disk, depend on the locked ASUS PC's support.<br /> <b>4.</b> Boot the locked ASUS computer from the password reset disk. <br /> Note: You may need to config bios setting to set it boot from the password reset disk. The 2 articles can help you.<br /> a. <a href="http://www.windowspasswordsrecovery.com/getting_started/bios.htm">Boot from the CD/DVD-ROM</a><br /> b. <a href="http://www.windowspasswordsrecovery.com/getting_started/bios_usb.htm">Boot from the USB Flash Drive</a><br /> <b>5.</b> On the password recovery Windows, select the user account that you forget its logon password, click "reset" button.<br /> <b>6.</b> Confirm you action, then that user's password will be removed.<br /> <b>7.</b> Disconnect the password reset disk, and reboot your ASUS computer. You will access Windows OS without password ( blank password ).<br /> Finally Get away from the troubles of forgetting ASUS PC Password, no matter it is bios/cmos password or Windows password. <br /> Tips: <b>1.</b> The Windows Password Recovery Tool supports all versions of Windows OS, including Windows 7, Vista, XP, 2000, 2003, 2008. It is popular way of regain your password, even you don't have a password reset disk. <br /> <b>2.</b> Keep in mind that this tool can be only used on your own computer, never try to use it to crack PC password without permission. Otherwise, you will get into trouble by law.<br /> <b>3.</b> You can <b><a href="http://www.windowspasswordsrecovery.com/create-windows-7-password-reset-disk.htm">create a ASUS Eee Pad Password Reset disk</a></b> before you forget password. <br />
on May 23, 2011 | Computers & Internet
How can i bypass bios password
Solution 1: Unable to power on the notebook.
1.1: Reset hole available on the bottom?
1.1.1: Reset hole available. --> Use a spiculate pin to tip the reset hole.
1.1.1.1: Problem solved. --> Able to power on.
1.1.1.2: Problem persists. -->1.2
1.1.2: Reset hole unavailable. --> 1.2
1.2: Try to power on just using battery.
1.2.1: Able to power on. --> 1.3
1.2.2: Unable to power on. --> Check the adapter indicator.
1.2.2.1: Adapter indicator on. --> Try to power on just using adapter.
1.2.2.1.1: Able to power on. --> 1.3
1.2.2.1.2: Unable to power on. --> Contact ASUS service center for help.
1.2.2.2: Adapter indicator off. --> Adapter problem, check the cable or contact ASUS service center for help.
1.3: Try to enter the BIOS by pressing F2 button when ASUS logo appears.
1.3.1: Able to enter the BIOS. --> 1.4
1.3.2: Unable to enter the BIOS. --> Contact ASUS service center for help.
1.4: Try to enter the Operation System.
1.4.1: Able to enter the OS. --> Reinstall the OS for a try.
1.4.1.1: Problem solved. --> Able to power on.
1.4.1.2: Problem persists. --> Contact ASUS service center for help.
1.4.2: Unable to enter the OS. --> Contact ASUS service center for help.
this one is copyed.
May 11, 2014 | ASUS Computers & Internet
Resseting cmos n82jq
Not sure what you're trying to do, but ASUS has instructions on entering the BIOS so that you can update it. There is also a forum that shares some info on ASUS bios reset passwords by date here: ASUSTeK Computer Inc Forum laptop bios password reset
Nov 12, 2013 | ASUS 14" N82JQ-B1 Laptop PC with Intel...
Bios backdoor for asus laptop
BIOS passwords can be reset in two ways:
1. using software 2. using hardware.
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html
CmosPwd - Cmos password recovery tools
http://www.syschat.com/download121.html&act=down
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Jun 29, 2012 | ASUS K72F otebook
How can i bypass my asus k52J bios password
http://reset.fanhow.com/reset-bios-notebook-asus-k52j
May 31, 2012 | ASUS Computers & Internet
P4S133 bios settings...
Check the jumper for the bios, it may be set for clear. (not an uncommon boo - boo). Move the jumper back to default pins.
Apr 09, 2008 | ASUS SiS Chipset P4S133 (P4S133/PA/LAN)...
Cant login to bios
Try doing a bios reset using the BIOS RESET button on the motherboard, usually located near the battery.
Jan 12, 2008 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
354 people viewed this question
David Payne
David Payne
