Question about HEWLETT-PACKARD Hewlett Packard HP-Compaq Genuine 217095-001 20 GB 4200 RPM IDE 2.5 Inches NoteBook . Pull. In Stock. Hard Drive
HpWon't turn on
Plugged in and 110volts t the printer. Will not come on after pushing the on button
    Brigadier General:
  • HEWLETT-PACKARD Master
  • 3,400 Answers
YOU PROBERLY FRYED IT.
Posted on Jan 01, 2014
Hi I have a White knight tumble dryer it's not heating up I've tried the reset button but it doesn't push in
1. Check to make sure you have proper voltage to the unit. 110volts for gas and 240volts for electric dryers.
2. Make sure a heat setting is fully selected by making positive contact to a heat switch/setting.
3. Turn off/unplug unit from its power supply.
4. https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Click on link for repair/disassembly help on your particular model.
Oct 20, 2017 | Dryers
My 926 Dell Printer dos not turn on. The On light is off.
Make sure it is plugged in real good. It may have been dislodged somehow or not plugged in all the way. this can happen without us knowing it. :-)
Oct 18, 2014 | Dell FH214 926 PHOTO ALL-IN-ONE PRINTER
The printer will not start when you push the start button. It is a new printer
Most likely, this issue might be caused by Start button being stuck. If you can't turn the product ON by pushing the Start button, double check if the Start button is somehow stuck, and also make sure that the unit is firmly plugged in to the wall outlet. If that doesn't resolve the issue, try a different outlet because you might be experiencing power outage on the outlet where it's plugged in. If that won't resolve it, I'm afraid the unit has to be serviced.
Apr 19, 2011 | HP Officejet 6500 Wireless All-in-One...
Printer will not turn on. When the power button
Check the cord and ensure it is plugged properly.
If it does not turn on then your power button has to be replaced
Nov 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma IP2000 not starting
dear,
uninstall the software of your printer and reinstall it...hope it may work.
thanks.
Jun 16, 2009 | Canon PIXMA iP2000 InkJet Printer
I have a HP Officejet H470wbt printer ,sometimes it starts to print, and it will print about an inch or so of the invoice than stops, you have to push the resume button, then it kicks out an empty sheet.
I did what they call a power reset. If your printer is turned on, turn it off, if it is plugged in, unplug it, if it has a battery, take it off, push and hold the power button for thirty seconds, replace battery, plug it in and turn it on, wait till all the lights quit blinking and try printing, I did this and it has'nt givin me a problem since
Apr 01, 2009 | HP Officejet H470wbt InkJet Printer
MY UPS PRINTER IS NOT RUNNING ZEBRA: UPSLP2844
Bit of a tough one to know where to start "Printer is not Running"
They usually sit on a bench and do not run anywhere :-)
Is your power supply plugged in?
Is there a green light on the power Supply?
Is the printer turned on?
Does the green feed button cause a label to eject?
If yes to all the above then try a reset
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Dec 09, 2008 | Zebra LP 2844 Thermal Printer
Power Problem
power down only apply if you power down button put the hold 5 second printer automatic power down after that u unhold
Feb 26, 2008 | HP PSC 1610 All-In-One InkJet Printer
Possbile battery
It could be a battery fault, have you tried it without the battery?
Sep 07, 2007 | Acer Aspire 3680 Laptop
HEWLETT-PACKARD Hewlett Packard HP-Compaq Genuine 217095-001 20 GB 4200 RPM IDE 2.5 Inches NoteBook . Pull. In Stock. Hard Drive Logo
41 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
