Question about Shuttle 9094 Emax Remote Control Helicopter
My silver bullet helicopter wont take off, the top blade is spinning but the bottom one isnt
    New Friend:
Both weights are on the top blade. It still doesn't have enough power to take off. The tops are spinning, but the bottom isn't. I held in the trim button, but nothing seems to work.
Posted on Dec 24, 2014
    Master:
  • 996 Answers
Adjust rotating gears with the help of a washer to connect properly withou slipping
Posted on Dec 23, 2014
  • Rani wadia
    Rani wadia Dec 23, 2014
    without slipping
  • 4 Answers
Kindly check the rotor carefuly.. there is one white/black color rotor fixed on the bar of Motor rotates whith motor and there is anoter rotator which attached parally with its i.e once motor rotator moves the another ones also moves (which connected with the rod of Blades) some times these rotators gets loose by time and makes the rotation of Blades weak. kindly connect the same tightly and check....
Posted on Apr 07, 2014
3 Suggested Answers
SOURCE: silver bullet helicopter wont stop spinning counterclockwise
i would continue to hold the trim. this happended to mine and i held the trim for a couple of seconds and it leveled out. also i have a problem, mine wont generate enough lift to take off. do you have a solution for that?
Posted on Feb 17, 2010
SOURCE: I have Brookstones silver bullet
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Posted on Jan 13, 2011
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
A brook stone RC silver bullet helicopter. Quite a bit of hair got in it so I cleaned the hair out and took it apart to see if I could find anything obviously wrong, I only took the plastic shell off
What your witnessing is that the blades are not catching on the spindle, normal function locks the central unit to that silver shaft that drives the blades. There is not enough friction driving them so they just lazily spin like that. There should be a secondary coupling link that helps engage the blades for flight please refer to the manufacturing specifications.
Source: http://www.brookstone.com/static/customerService.jsp?panelId=100011
Oct 15, 2012 | Toys
The bottom blade's of my brookstone silver bullet helicopter keep's on hitting the tail of it.
One of the weights on the rotor has fallen off. There should be a silver weight on each end of the top skinny rotor
Jan 17, 2011 | Toys
I have Brookstones silver bullet u control helicopter and have a problem. I crashed it, and when I went to fly it again it seems like the bottom blade is hit off the tail of the helicopter. Do I just...
Dec 27, 2010 | Shuttle 9094 Emax Remote Control...
Silver bullet helicopter wont stop spinning counterclockwise
Feb 13, 2010 | Shuttle 9094 Emax Remote Control...
I have an apache 3 channel helicopter.the top blades no longer spin so the helicopter just spins clockwise very quickly
Same problem I had. There are two motors. One to spin the top blade and a second to spin the bottom. My motor was defective out of the box to spin the top blade. Very poor quality as my AH 64 had a bad circuit board. I had to take parts from one to fix the other.
Sep 04, 2009 | Apache RC Mini Helicopter AH-64
My new u-control helicopter is experencing spinning
how much is it spinning after and if not to much adjust the st. trim on the controller.
Aug 06, 2009 | Shuttle 9094 Emax Remote Control...
Shuttle 9094 Emax Remote Control Helicopter Logo
403 people viewed this question
Top Shuttle Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Shuttle Toy Expert? Answer questions, earn points and help others
