Question about Ovens
Removed aluminium foil stuck to oven with pool acid - is it safe to use now?
Aluminium foil has stuck to the bottom of my electric oven. I have removed the aluminium foil with small amounts of pool cleaner (muriatic acid) but the finish is now dull. After removing the alumnium I cleaned the oven first with a paste of baking soda and water, then with oven cleaner and finally with warm soapy water. I have also run the fan with the door open twice for ten minutes. However when I turn the oven on there is still a slight smell. Is the oven safe to use (ie is there any chance any remaining fumes or chemicals could get into the food I am cooking?) and does anyone have any suggestions as to how to get the shiny finish back? Thank you
Kill the acid with some caustic soda - normal oven cleaner
then you can cook free of acid fumes
Posted on Jan 01, 2014
I melted a plastic bowl in oven I scraped most of it out while it was hot but now I have thin spots of plastic film, I need to know how to clean without ruining the surface of my oven cavity
Warm the oven to 100c allow to cool for 15 mins with door open then lightly scrub with a ball of aluminium foil this won't scratch ad foil is softer than the oven lining
Jan 06, 2018 | Ovens
Will aluminum foil protect credit cards
No! They make special cases for protecting them from radio wave theft devices.
Oct 06, 2015 | Ovens
MELTED ALUMINUM FOIL ON BOTTOM OF OVEN FLOOR: Have a Kenmore ceramic smooth top range. We placed a piece of aluminum foil on the very bottom of the oven as we like to bake our pizza on the rack but...
I would try a copper scouring pad.
Aluminium is very soft - Mohs hardness of 2.75
Copper has a Mohs hardness of 3, just slightly harder.
https://en.wikipedia.org/wiki/Hardnesses_of_the_elements_(data_page)
Ceramic tile has a hardness of 7
Mohs Hardness Scale
This means the copper scouring pad should be able to remove the melted foil without scratching the ceramic - but test first to be sure.
Mar 10, 2017 | Ovens
What brands of aluminum foil are safe for convection ovens
Any good quality heavy duty foil should do. Temperatures in conventional ovens never come near the melting point of aluminium, although all aluminiums for a slight health risk.
Jan 16, 2011 | Whirlpool Ovens
We too ended up with melted reynolds wrap standard aluminum foil lined and then melted to the bottom of our oven. The smell was terrible. The thing was, we didn't know it was the aluminum foil until we had...
It is very difficult to melt Teflon; 326.8 degrees Celsius or 623.24 degrees Fahrenheit, hotter than most ovens! Rapeseed cooking oil will have long before caught fire.
Teflon is not used on oven floors, walls or racks.
The melting temperature of aluminium foil is 660 degrees Celsius (1,220 degrees Fahrenheit) at standard pressure, so it won't melt with temperatures encountered in a standard household oven!
Toxic fumes from the Teflon chemical released from pots and pans at high temperatures may kill pet birds and cause people to develop flu-like symptoms (called "Teflon Flu" or, as scientists describe it, "Polymer fume fever").
Oct 15, 2017 | Ovens
I have baked on aluminun foil on the bottom of my self clean oven did the cycle to self clean and the aluminum foil is still stuck on the bottom what can I do to remove it without ruining the surface
If the bottom of the oven is enamelled or has a pyrolytic self cleaning surface then you can use caustic soda to remove aluminium foil.
Many oven and hob cleaners contain caustic soda and those which do always advise that it's kept away from aluminium parts precisely because of it's effectiveness in turning aluminium into grey foamy goo!
If you're in doubt as to whether your oven floor is caustic soda resistant then try a small test patch first.
Please note that caustic soda is extremely corrosive so you'll need to keep your hands and arms covered and preferably use eye protection as well.
Sep 20, 2009 | Electrolux ICON Designer E30SO75ESS Oven
Aluminum foil stuck to new oven bottom - how to remove
(Wear a professional n95 mask and rubber gloves). Use a straight razor and scrape off as much foil as possible. Get a hold of Mercuric or sulfuric acid. BE CAREFUL not to spill anywhere, work close to a stainless steal sink. Poor a little in a small glass container and bring over stove porcelain surface. Pour the acid onto the foil and wait 3-4 minutes, use paper towel to wipe off the acid, and then a soapy wet rag. Repeat process until all foil is dissolved. Then wash surface thoroughly and repeatedly with a soapy dish towel. Once complete run water in the sink for 5 minutes till any possible remaining accid is flushed from the sink. The foil is gone and the porcelain is preserved. Works great! (Don't breathe the fumes and ventelate the area or move the stove outside)
Jan 20, 2009 | Kenmore 47783 Electric Single Oven
Tin foil stuck to bottom of oven
if not a lot of foil get that easy off thats made for self cleaning ovens soak it let it sit then wipe make sure you get the one that says safe for silf cleaning dont scrape soak then after wipping off run self clean
Dec 27, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
168 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
