Question about Invacare Pronto M51 Power Wheelchair
Chair has power but when activate toggle it does not move is there a reset somewhere?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Hmm check levers under your seat make sure they are engaged or press horn 2 times within ten seconds to unlock the joystick
Posted on Jan 19, 2014
Spj-80, model 1122190. Why doesn't it move?
you may have a current rollback problem you will need to charge the Chair for 14hrs. with the Joystick on! This will reset the circuit. Charge with the joystick on! It is okay it won't hurt a thing, in fact from now on always charge with the joystick on.
Sep 29, 2015 | Invacare Pronto M91 with SureStep
Looking for reset button oN TDX SD power wheel chair
Hello, Invacare does not have Reset Buttons on the power for the batteries. They only use fuses. Now if the joystick has a display and it says to press a reset button and it did not used to say that then the programming has be lost or changed by the rain or battery power. You will need to have someone with an Invacare Programmer reprogram the chair or a reset switch can be purchased that will plug into the joystick and allow you to get pass the Press Reset command on the joystick.
Jun 14, 2015 | Drive Health & Beauty
How to toggle a headrest to reverse
What kind of chair and head rest do you have?
Most headrest require a reset/mode switch to be activated when you do not have your head touching any part of the headrest.
Sep 14, 2014 | Invacare Health & Beauty
What does my tss300 power indicater keep flashing left to right but won't move. batteries are fully charged and reset is set?
The chair is more than likely in free wheel. There are two levers under front of the seat (yellow). Pulling them forward should place the chair in freewheel and pushing the levers back should place the chair in drive. Once in drive mode, turn power on to reset joystick.
Apr 27, 2014 | Pride Mobility Pride TSS300 Power Chair -...
Invacare power chair model #1089384; is stuck in the reclining position and won't come back up
Hope you have had this fixed by now. But in case not and you are not able to use the chair.
If the chair still drives it's not batteries. The toggle switch box should be ok if there is no visable damage to it. Bad connections of the wiring from the toggle switch box to power or the recline or tilt motor should be inspected. A electronic tech is needed for most electronic failures.
Jan 18, 2011 | Invacare Health & Beauty
Wheelchair lights are blinking and I cannot move the chair. It did it the other night, and my husband held something down for a little while and it fixed it. He cannot find the resoution n the manual now....
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. Try to reset your system by turning off the power chair, moving the manual brakes from drive to push and then back to drive and turn the power chair back on to see if that clears the problem. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Nov 29, 2010 | Invacare Pronto M51 Power Wheelchair
Pride Jet 2 power chair with with 3 red and 3 yellow lights flashing. Batteries checked ok under load, all connections have been checked. I moved the chair and it would not move again. Just that quick.
Hi. The fault code you have is called the "Inhibit active".
It can be caused by a blown charger fuse, which causes the charger inhibit to activate.
Also if the 3-pin charger inhibit connector is not plugged in properly, or the connector is faulty, then the charger inhibit feature will activate.
Hope this helps. Neil.
Jun 22, 2010 | Jet 3 Ultra Power Chair
All lights are flashing, and chair won't move when I try to use
The flash codes for the VSI controller used on this chair are located here:
These will tell you what the fault is; repost with more information.
May 23, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Compass 'tilt in space' chair does not tilt
The TRO is a new tilt-system offered by Golden so I am not familiar with any glitches it may have, but I would first check to make sure that the connections from the toggle leading back to the tilt-box in back are all well-connected. Unplug, and replug all connections as far back as the power supply for the tilt system, which goes back into the base of the chair to the controller. It's important to completely unplug and replug and not check them visually, as a loose connection cannot always be confirmed by sight alone. Also, check the fuse to the tilt feature. I am not sure if this one has a separate circuit breaker for the tilt option, but if it does, check that as well. The toggle protrudes out from the front and is subject to impact damage. A lot of folks try to get 26 inch wide chairs through 25 inch wide doorways, as I am sure you've found out. If you've rammed the toggle into a door frame, table or other fixed object, it may be the switch. Checking its operation with a voltohmeter is the likely approach to insure that the toggle is not damaged and is doing its on/off duties. The fact that you aren't getting a power available light seems to make the toggle not the culprit, but it's worth a shot.
Hope this helps. Good luck.
Mar 19, 2009 | Electric Jazzy 1115 Power Wheelchair
Invacare Pronto M51 Power Wheelchair Logo
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
