No power to TV. Just stop working like it overheated or blew something. I have only had it a couple of days. It will not switch back on again via the remote or the switch on the tv. There is no static from screen it is dead dead dead.
Check and replace damaged component/s at its main power regulator board, or replace the board as card basis. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Try it in Mosaic view.
SOURCE: Olevia LT42HVi - Need to toggle power switch on back of TV off/on all the time
You swapped the power strip. How about swapping the cord with another. Most LCD and Plasma TV used a cord similar to the cord use for the power supply of PC (IEC line plug). If still it doesn't work. Time to open the back to access the connector terminal which came loose (Due to heat) if not soldered directly to the power supply PCB. Just pinch the spade crimp, better still solder it. Make sure to lay the TV flat, face down on a smooth surface table if you're repairing it yourself.
Good Luck.
SOURCE: flat panel tv blows fuses
next to the fuse that blows is 4 large black diodes.one of those is common to short out. the bad one would give you areading of zero ohms when checked with a meter. or just replace all 4.most likely its location D603. hope this helps
SOURCE: TV switching to standby
Hi.i had exactly the same problem with my bush 37 inch lcd tv and i took it to a friend of mine who is a t.v electrician he said it was a component in the back of the tv which he replaced and its now working fine.
SOURCE: Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
