Question about LG 47 47LV5500 47 LCD TV
I mistyped PIN in network setup for LG 47LV5500; need to retype but it won't let me
I need to retype the PIN but it won't let me; only option is Enter
I entered the wrong email address to access my iCloud account and need to know how to change it.
your original email address is your iCloud acct email, unless you changed the acct info. if you just mistyped, then retype because you could not get into a mistyped email address and get in. or is it a locked acct your are trying to break into?
May 26, 2016 | Apple - iPad Air 2 Wi-Fi 64GB
LG 47lv5500 shows wrong colors
Hi, Probably you are gonna have to change the main board! Best Regards! Bye!
Serge!
Jul 03, 2015 | LG 47 47LV5500 47 LCD TV
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Enter client device pin
The client device PIN is a WPS method to connect to the network
I would suggest you disable the WPS feature and go with standard WPA or WEP
To get the PIN :
Turn off / Disable wifi in the laptop
  1. - Hardwire the computer and router
  1. - Open the router setup page ( http://192.168.2.1 )
  1. - Click wi fi Protected setup on the left side
  1. - Scroll down a little and you can find the router PIN
  1. - This is the number that you need to enter in the device
To Enable WPA Security in the wireless network
  1. - Leave the password blank and click submit
  1. - Disable Wi Fi Protected setup at the top and click Apply Changes
  1. - Click Security under wireless on the left side
  1. - Change the security mode to WPA
  1. - Type a password
  1. - Save the changes.
Dec 17, 2013 | Belkin F5D8631-4 Router (F5D8631au4A)
No picture, only sound on LG 47LV5500: how do I get picture back?
Definitely odd for sound to come through and not sound, especially via an HDMI connection.
I would contact LG for support, your TV could be defective.
Good luck
May 28, 2012 | LG 47 47LV5500 47 LCD TV
Where do i find network key?
Follow these steps:
1. Open Internet Explorer then type the numbers 192.168.1.1 on the address bar then press enter.2. Make sure that the pc is connected via hard wired connection.3. After typing the numbers on the address bar, the site should be on the modem settings page.4. Go to basic settings or look for the Wireless Tab then select and browse thru it.5. Under SSID, there will be security option, check if you are using the WEP or WPA security key.6. Whatever the WEP or WPA key is, that is your network key. Since you are already on the said tab, it will be better if you are going to retype or change the WPA - Pre Shared Key and make sure that you will remember whatever the Pre Sahred Key you used.7. Select Save and apply then exit.8. You are good to go then, using your network key..
Thank you and kindly rate this post.
Jan 02, 2012 | Vizio XWR100 Wireless Router
I need to set internet to my ks360 how do i doit
    1. Press Menu (left soft key)
    2. Select Connectivity
    3. Select Network
    4. Select Access points
    5. Press Options (left soft key)
    6. Select New access point
      Note Slide the handset open to access the keypad
    7. For the Name enter #Profile
    8. For the APN enter #InternetAPN
    9. For the User name enter #Username
    10. For the Password enter #Password
    11. Ignore Primary sever and Secondary server these are preset at 000.000.000.000
    12. Press Save (the OK key)
    To setup the Internet profile
    2. Select the Browser
    3. Select Settings
    4. Select Network Profiles
    5. Press Options (left soft key).
    6. Select New profile
      Note Slide the handset open to access the keypad.
    8. For the Homepage enter #Homepage
    9. Set Proxy to #Proxy (to change press the Navigation buttons left or right).
    10. For the IP address enter #InternetProxy
    11. For the Port number enter #InternetPort
    12. Scroll to Access point and set it to #Profile (to change press the Navi buttons left or right).
    13. Press Save (the OK key).
    14. Scroll to #Profile and press Activate (the OK key).
    15. The Internet is now setup
Aug 20, 2011 | LG Cell Phones
LG 47 47LV5500 47 LCD TV Logo
14 people viewed this question
Computer Repairing
Computer Repairing
