Question about Electrolux EW1000i Front Load Washer
My ewf14108w does not spin and shows fault E20
Stops during both wash and dry cycles shows error E20 any ideas
hi e20 is fault code for not draining efficiently either a blockage in the pump or hoses to or from it. can also be a blockage under the sink if its connected by way of a spigot to the waste. If not any of them the pump is faulty and needs replacing.
Jan 22, 2011 | Zanussi Washing Machines
E56 on electrolux EWF14108W
e56 is a motor or motor control circuit board fault
May 29, 2010 | Electrolux EW1000i Front Load Washer
Hi, Our Electrolux EWF1083 is not spinning and ...
Hello,E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
The drain pump may be blocke.check www.serviceforce.co.uk
Thanks
May 19, 2010 | Washing Machines
E20 showing on display, machine still got water in
E20 is related to the pump and as you say a strange noise is there I would check the filter for foreign objects.E90 is normally a communication problem between the main programmer and the display module.There may have been a fault in the pump which has caused a fault at the Programmer.That model was first produced in 2002 but it is worth checking pump and filter first.If you find anything in filter then clean it out and give it another go the E90 error may have been a glich.Best of luck.
May 04, 2010 | Zanussi FJD1666W Front Load Washer
E20 message want spin
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Apr 29, 2010 | Frigidaire ATF6000ES Front Load Washer
E20 fault display
E20 is a fault either in the filter/pump or drain.
The water must be drained thru. the little hose by filter or get machine to back door and undo filter plug and drain onto back step its quicker.With filter out see if any blockages,shine torch up in filter hole turn to spin/drain and see if pump blade spins if not then get long screwdriver and turn blade to free if no joy pump has to come out to free,hopefully this will work and refit plug and check for leaks.Then try again.
Good luck.
Apr 19, 2010 | Zanussi ZWF1420W Front Load Washer
Error code E20
Hello there
the Dreaded E20 fault is a drain problem
washer will show the E20 code and may not spin.
So i would first look for a clog in the hose right before the water pump there is a little cup in the black hose that could be full of suff if so empty the cup and it should work good after this
hope this will help you out
Best regards Michael
Dec 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
Won't spin.
wont spin because the unit is not drainning water...wont spin with water in it must drain first...check drain hose for kink,,,check waste pipe for blockage...and than check pump...onthejob
Dec 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Electrolux EW1000i Front Load Washer Logo
24 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
