Question about Lectrosonics Gemini UF2064L 64 Channel Wireless Dual Lavalier Mic System Microphone
Using sampson C01U with chromebook - Lectrosonics Gemini UF2064L 64 Channel Wireless Dual Lavalier Mic System Microphone
Have a chromebook and it wont download software for epson printer
chromebooks use google cloud print. they don't use drivers like for windows. maybe this video will help
Installing Local Printer On Chromebook
Nov 27, 2015 | Epson stylus nx110 All-In-One InkJet...
Sampson sc16 spare parts
Check Out gedusa.com Or call 330-425-3876 and ask for Ted or Joe. That company manufacturers the replacement parts for Sampson.
Mar 25, 2014 | Saws
My samson microphone c01u works but i cant hear my mic thru my speakers it does not record out
That's normal. You're supposed to record a track and then play it back. In order to hear it live you would need to enable "software playthrough" in your recording software, but there will be a delay, so it probably won't be much use.
Aug 27, 2011 | Samson Audio C01upak C01u Microphone and...
Where can I download the C01U Driver Software ?Could you please send the link to me ?
I found three posts to assist you.
1. http://samsontech.com/products
/productFAQs.cfm?prodID=1810&brandID=2
2. http://download.cnet.com/Samson-C01U/3000-18493_4-84344.html
3. http://www.samsontech.com/usb_mics/driver_update/
Aug 21, 2011 | Samson C01U Consumer Microphone
I connected the microphone on my computer and the system rec.ognized the microphone but I don't know how to use it with the computer to bring out sound
The thing is that the Samson C01U was not designed for live applications. Your solution, if you like delayed sound, is to use Virtual Audio Cable. Otherwise, I would get either a Samson GTrack, or invest in a cheap but functional mixer with a good mic. If you want to record however, you go into your audio recording settings and select the C01U as the recording mic. If you record and hear little sound, go into sound manager... Click on properties and select on Samson C01U. A one channel volume control will pop out. change the volume and record. BTW, a good audio program is Audacity... It's free. I hope that I have helped you...
Apr 27, 2011 | Samson C01U Consumer Microphone
Samson c01u vista drivers
No. From their website...
Note: Samson SoftPre is not compatible with Windows Vista however the C01U, C03U and Q1U are all Plug-and-Play compatible with Windows Vista.
Aug 15, 2009 | Samson Audio C01upak C01u Microphone and...
C01u PROBLEM PLS HELP ?!
That's the way it's supposed to work. It's a mono microphone, so there's only one signal to record.
Set up your recording software so that it only records the Left channel. It describes how to do this on the Samson FAQ page and in the Owner's Manual:
"In your digital audio workstation (DAW), create a mono audio track, and set it to the Left channel of the C01U (the Right channel should be ignored). Arm the track for recording, and adjust the input gain by using the software control in your computer's operating system"
Don't try to alter the pan so both sides are the same; that will just screw up the levels and noise.
Jan 08, 2009 | Samson C01U - USB Studio Condenser...
57 people viewed this question
Top Lectrosonics Audio Players & Recorders Experts
Michial Gueffroy
Karl Luedemann
Gerhardus Stroebel
Are you a Lectrosonics Audio Player and Recorder Expert? Answer questions, earn points and help others
