Question about Radio Communications
Bluetooth how to connect
How to connect bluetooth
Please someone help me. I've tried to connect to Bluetooth. I get so far along and then phone Bluetooth doesn't find the cars. Is there a fuse that might if gone? I did not get a manual with my car.
About 4,890,000 results (0.54 seconds) Search Results
    How to Fix Bluetooth Pairing Problems - Techlicious
    www.techlicious.com/how-to/how-to-fix-bluetooth-pairing-problems/
    Dec 29, 2015 - Determine which pairing process your device employs. ... Let's say you want to pair your phone with your car's infotainment system so you ..... If your tabletdoesn't come with built-in Bluetooth (and it looks like most, if not all, ...
    www.techlicious.com/how-to/how-to-fix-bluetooth-pairing...-/CP2/
    Dec 29, 2015 - Let's say you want to pair your phone with your car's infotainment system so you can .... i factory reset my tablet and now it wont find my bluetoothspeaker to pair! .... It doesn't look like you can revert to the previous firmware ...
    Bluetooth FAQ for Windows Phone ' Windows Phone How ...
    www.windowsphone.com/en-us/how-to/.../bluetooth-faq
    Windows PhoneRead the Bluetooth FAQ for Windows Phone and get answers to common ... You can pair your phone with a variety of devices that use Bluetooth, such as the hands-free system in your car, headsets, speakers, ... Where can I find it? .... ?My phone doesn't reconnect to the Bluetooth hands-free system when I get in my car.
    iPhone 6 not connecting to car Bluetooth ' Apple Support Commu
Jan 27, 2016 | 2006 Ford Focus 2.0
Tip
How to connect Bluetooth GPS using mobile phone
<p>Once I explain how Bluetooth GPS receiver to connect from a mobile phone. Bluetooth GPS Receiver is a device that continuously transmits its position (longitude, latitude and speed) using the Bluetooth protocol. If your phone is Bluetooth-enabled phone, you can connect to a Bluetooth GPS receiver to determine its position. To locate, connect to Bluetooth GPS and mobile phone to get the NMEA sentences for location tracking, you can also program a Java (J2ME) for your phone. Your program should do the following tasks: <br /> <p><br /> <p>1. Bluetooth device within the search area. Each time a Bluetooth device is discovered, discovery listener device Discovered trigger procedure. In the search is completed, the trigger listener discovery process inquiry Completed. <br /> <p><br /> <p>2. Get the name Bluetooth. We have a choice to a group list of Bluetooth-friendly name of the devices found to store. We also need a vector to devices found to store. <br /> <p><br /> <p>3. Select Bluetooth GPS receiver from the list of found devices. <br /> <p>4. Find service by the GPS device. Bluetooth GPS Receiver provides an L2CAP service so that the program needs to find this service for GPS url connection string for. <br /> <p><br /> <p>5. Get connection string from the GPS device. Connection string to the URL will have this format Url = "btspp: Address / bluetooth /:" + + L2CAP_UUID "permission = false; encrypt = false"; <br /> <p><br /> <p>6. Sign up and receive sentences from the GPS device. After plugging in the url in step 5, you can open the connection and extract sentences from the connection string. <br />
on Jun 26, 2011 | Cell Phones
Tip
How to turn Bluetooth on and off on a BlackBerry Tour
The BlackBerry Tour comes with Bluetooth capability, but in order to connect to a Bluetooth device, you have to enable the Bluetooth functionality. When you're not using a Bluetooth connection, disable Bluetooth to avoid other devices from connecting to your BlackBerry.
- To turn Bluetooth on:
From the main home screen, press the BlackBerry button (to the left of the trackball) to go to your Home folder. Scroll down until you see the antenna icon for Manage Connections and click on it. A pop up list will appear; find Bluetooth on the list and click it to put a check in the box next to it. "On" will appear next to Bluetooth, and the Bluetooth icon will be displayed in the upper right corner of the screen. Your BlackBerry is now in Bluetooth mode, where it can connect and pair with other Bluetooth-capable devices.
Bluetooth can also be turned on from the Options folder, under the Home folder. Select Bluetooth from the list and when the screen comes up saying "Bluetooth: Disabled," press the BlackBerry button and then select Enable Bluetooth. If you've previously paired your Tour with other Bluetooth devices, the list of those devices will appear.
- To turn Bluetooth off:
From the home screen, press the BlackBerry button. Scroll down to Manage Connections and select it. In the list that appears, click Bluetooth to uncheck it and disable Bluetooth functionality.
You can also turn Bluetooth off by clicking Options in the Home folder, selecting Bluetooth from the list of options, then pressing the BlackBerry button and choosing Disable Bluetooth.
on Jan 14, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Can't get computers Bluetooth to connect with Bluetooth speaker
Install the sofware that came with it and then try. If your computer dosen't have bluetooth it cant connect. Usually you would need an extra piece of hardware to get bluetooth on your pc.
Jan 29, 2011 | Altec Lansing iMT525
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
Emerson bluetooth
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select (Serched bluetooth device) once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 14, 2008 | Southern Telecom Emerson Bluetooth Headset...
Installing a French ( Brand is Genius) keyboard to my Dell computer.
Pair to a Bluetooth Device (new and re-pair)
  1. Locate the Bluetooth icon in the lower-right corner of the computer screen, and compare the status to Table 1.
    (The Bluetooth icon may be hidden, click the Show hidden icons arrow to show any hidden icons.)
    Bluetooth Icon Status Enabled - The Bluetooth adapter is ready to pair with another Bluetooth device.
    Connected - The Bluetooth adapter is already connected to a Bluetooth device (if the desired device is not the one its connected to, it will have to be re-paired). Disabled - The wireless switch is off. For information on how to turn the wireless switch on refer to the
    Online User's Guide. None When no icon shows the Bluetooth driver needs to be installed, refer to Dell Knowledge Base Article:
    "How to Download and Install the Latest Dell Wireless Bluetooth Driver" Table 1: Bluetooth status
  2. Verify the following conditions have been met:
    • Batteries are Installed in the Mouse and Keyboard.
    • The Bluetooth adapter, USB Bluetooth adapter or 13/19-in-1 Media Card Reader is installed in or attached to the computer.
    • The latest version of Dell Bluetooth Wireless Keyboard and Mouse Bundle is installed,
      if unsure refer to Dell Knowledge Base Article: "How to Download and Install a Driver"
    • The Bluetooth device you are going to pair is within 30 ft. (10 meters) of the computer.
  3. Right-click the Bluetooth icon in the system tray.
  4. Click Add a Bluetooth Device.
  5. Turn on the Bluetooth mouse and press the Bluetooth connect button on the bottom of the mouse. The Bluetooth LED on top of the mouse should start blinking. If the LED does not blink, press the Bluetooth connection button again and hold it down for 2-3 seconds until the Bluetooth LED starts blinking.
  6. Click Next to start searching.
  7. Click the icon for the mouse to highlight it and then click Next.
  8. The connection is set up automatically. Once the connection to the mouse has been created, the wizard closes and returns to the Bluetooth Settings window. The new connection is now listed there. The link symbol under the mouse indicates it is connected.
  9. SetPoint will now launch and ask to check for updates, click OK. If an update is available click to download it.
  10. After the update has been applied, click OK.
  11. Turn on the Bluetooth keyboard and press the Bluetooth connect button on the bottom of the keyboard. The Bluetooth LED on top of the keyboard should start blinking. If the LED does not blink, press the Bluetooth connection button again and hold it down for 2-3 seconds until the Bluetooth LED starts blinking.
  12. Click the box next to My device is set up and ready to be found and then click Next to start searching.
  13. Click the icon for the keyboard you want to connect to in order to highlight it and then click Next.
  14. When the keyboard is connected, the Confirm Keyboard Connection screen appears. A passkey that has been generated for the keyboard is shown. Type in the passkey as it is shown on the screen. Note:
    The keyboard can only store one passkey. The passkey is unique to each computer. If you try to connect the keyboard to more than one computer, the passkey is changed each time you create a connection.
  15. The connection is set up automatically. Once the connection to the keyboard has been created, the wizard closes and returns to the Bluetooth Settings window. The new connection is now listed there. The link symbol under the keyboard indicates it is connected. You are now be able to use the devices.
Aug 25, 2017 | Trust Silverline Direct Access 12879...
Radio Communications Logo
66 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
