Looking for a part number for a GE WSM27THEWWW/WSM2700WWW
The door lock catch broke and looking to find the right part for replacement. This is the catch that holds the washer door.
3 Suggested Answers
  • 151 Answers
SOURCE: door stuck on lock cant open door.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement. if you need step-by-step instructions on how to replace the door latch:
This advice is for replacing the door latch on the Kenmore Elite or Whirlpool Duet FRONT LOADER washing machines.
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Posted on May 03, 2009
jsrock516
  • 5911 Answers
SOURCE: whirlpool duet we broke the catch that holds door closed on washe
If you are referring to the door latch mechanism on the door facing, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
If you are referring to the catch on the door itself, it can also be replaced. Just remove the two Torx (T-2) screws that hold it in place and remove. Replace as necessary with a new catch. Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If the model number is correct, the part number for the door latch is 8182634. The door catch part number is 8181651. You can view these parts under the "Door and Latch Parts" heading as items 7 and 9.
If you have any questions, please post back and let me know. I hope this is helpful to you.
Posted on May 03, 2010
Frigidaire washer door catch is stuck, washer won't run
After looking at the schematic of this machine it seems that the door AND the control board have to work perfectly together in order for the safety mechanisms to operate correctly. You may have a bad control board or a loose wire. The best thing to do is look closely at a schematic and make sure that everything looks right. here is a blueprint: http://www.pcappliancerepair.com/model/index.php?id=FWT449GFS1
Jan 03, 2014 | Frigidaire Affinity ATF7000E Front Load...
Ge pfs22mi door gasket
This is going to be tricky so watch the video and tell me if the answer to you question comes out and resolved by the tricks revealed in the below video.. Sea Breeze
When you say latch can you tell me the part number of the latch you say that you need replaced? Here is a link to the parts you are describing HERE
GE Profile French door bottom freezer Model # PFS22MISBWW Door Gasket and related parts
Apr 01, 2013 | GE Profile Bottom-Freezer Refrigerator...
My toyota windom 1991 power windows..power seat..central locking..boot release catch and petrol cap release catch are all not working...does someone know what the problem could be please.
  • You need to open up the drivers side door and look at that harness that stretches between the door and the door frame. Inside that harness are the wires for the electronics in the cabin and then some.
  • Over time those wires get pinched and crack and break. So you need to splice the casing open the long ways and inspect the wiring. Your looking for broke, split, rusted, bulging or otherwise negated wiring. The boots on either side may need to come off to look up inside for broke wires as well. Usually it's pretty evident which wires are messed up but sometimes you have to do a little digging.
  • When you find the broke wire[s] splice some new wire[s] in and use electric tape to re-insulate.
  • This is a common problem across the board with many car manufacturers and repairing the harness almost always is the fix in a situation such as yours.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards,
Tony
Oct 14, 2011 | Cars & Trucks
Whirlpool duet we broke the catch that holds door closed on washe
repairclinic.com
May 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I want to replace the door catch on my wta 3100, How?
Yes the door has to come off and be taken apart I wish they made a better way of doing this but there simply isn't. You've got it right.
Apr 02, 2009 | Dryers
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
GE OVEN/RANGE INSIDE GLASS ON DOOR SHATTERED.
You will need a window pack, part number WB56T10152 which is not hard to replace. You should be able to order it right from GE, or an appliance repair firm can get it for you, often without extra shipping if they can combine it with other parts they need to order. Should set you back just over $100. You can remove your oven door to make it easier to work on. Use a little screwdriver to pull down the little square hole you will see on the top of the hinge opening on the frame of the oven on each side. That little metal part will lock the hinge open. Next, lift on the door and pull it toward you. The hinge actually stays with the door and lifts right out of the rectangular opening in the oven frame. Reverse procedure to reinstall repaired door.
Nov 29, 2008 | Frigidaire FEF336BC Electric Kitchen Range
GE spacemake microwave handle door
Apparently the part number for the black handle is WB15X10020 and the white one is WB15X335.
You can order either and find find helpful exploded view diagrams here.
Enter the part number to order the part, and enter your model number to find the exploded views.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Washing Machines Logo
Top Washing Machines Experts
