Question about Apple iPod nano
'disc mode'displayed in window, large tick and o.k to disconnect. machine will not respond.
Disc mode is displayed on screen, with alarge tick showing underneath. Also showing 'ok to disconnect. I pod will not respond.
  • 342 Answers
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If for any reason this does not resolve your disc mode/frozen iPod issue please do let me know and remember to rate :)
Mel
Posted on May 20, 2009
Toshiba REGZA won't play DVD. Shows "disc loading" then goes to wide screen mode, but then ejects the disc. Whats up?
Sounds like the laser pickup unit to the DVD player is faulty. Contact any service technician to replace it. The disc mechanism should be taken out of it to replace this part.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 17, 2014 | Toshiba Regza 32LV67U 32 in. LCD HDTV
When the computer boots, it display bluescreen
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If after running the Check Disk Utility you still have problems you will probably need to reinstall windows. Look into doing a Repair Install so that you don't lose your data.
Apr 24, 2012 | HEWLETT-PACKARD 630 Notebook
When i boot into the operating system which is win7 machine freezes and shows up a blue screen.when i placed the hard disk into a usb external case and connected it to a pc a message box showed saying i...
Get a windows 7 install or repair disc. Make sure your pc boots from the disc drive. When you get to the installation screen tick REPAIR YOUR COMPUTER. Then select the installation you want to repair and choose STARTUP REPAIR.
Mar 13, 2011 | Fujitsu (MJA2320BH) 320 GB SATA 3 Hard...
Player still searching & making ticking noise.
you will need to clean the lens whith alcohol and a soft cloth.
Mar 28, 2010 | Polaroid PDM-1040 Portable DVD Player
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Cannot turn off progressive scan mode on blue screen to play dvd
If you have not already seen this or done it - it worked for us:
On page 18 of the user manual under Progressive scan there is a Caution which says - If you set Progressive Scan to On in error, you must reset the unit. 1) Remove any disc from the unit and close the disc tray. See that "dISC " is displayed on the display window. 2) Press STOP (9) and hold it for more than five seconds before releasing it. The video output will be restored to the standard setting and a picture once again be visible on a conventional analog TV or monitor.
May 20, 2009 | Zenith XBV442 DVD Player/VCR
Display off
Boot into safemode. push F8 on startup until safemode option appears. If computer displays windows there, then it's most likley your resolution or your monitor frequenzy set to high/low.
change the resolution in safe mode, and the the frequenzy to 65 then restart your computer in normal mode.
Dec 21, 2008 | Computers & Internet
Mini Disc Not Working
Pull the power cord. Make sure the three-position switch with "REC/Standby/PLAY" is in the middle position, then plug the cord back in. Wait a minute, then press POWER. Now load a disk and wait 1 minute for it to read the Table of Contents (TOC). Either it will show the tracks, or it will say 'empty disk'. Let us know what happens from there, okay?
Oct 06, 2008 | Sony MDS-JE480 Mini Disc Player
Sony ipod
I want a buy sony ipod and please tell me? which is fluency voice is ipod and about this ipod rate?
Jul 04, 2008 | Sony Car Audio & Video
Apple iPod nano Logo
141 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
