Question about Samsung Galaxy Tab 2 7.0
When charging battery it only shows 2 bars and the screen goes blank and repeats itself and the tablet never charges.
The battery will not charge. When I plug in to charge the image of the battery turns on in the middle of the screen, and it shows tat it is charging with 2 bars that go across the battery and it doesn't advance all the way across the battery. I let charge overnight and it's doing the same thing repeatedly where the screen comes on and shows the battery on the middle of the screen it goes across 1/4 of the way not all the way across then turns off and starts doing the same thing all over again.
KingDWS
  • 1606 Answers
SOURCE: My galaxy tablet was fine
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
Posted on Mar 23, 2012
  • 44 Answers
SOURCE: Vibrating when charging every 5 seconds. Message says battery disconnected?
Clean connections at battery source. Check adapter and plug of adapter for power and clean terminal of adapter and where it plugs into unit also.
Posted on Sep 21, 2012
susannrosswa
SOURCE: my tesoar tablet showed charging for 3 seconds then that was it now it wont turn on it wont do anything
I have a hacker inside my Samsung galaxy 8 notebook, he controls my ph and I pad, how do I break the tracking link.
Posted on Mar 22, 2014
Tech_Mate
  • 680 Answers
SOURCE: Frozen tablet.
If it does happen again I would replace the battery. They only last for about three years.
Terry
Posted on Apr 01, 2014
  • 114 Answers
SOURCE: my tablet won't turn on after i charged it
Try holding down the button on corner end and at same time hold the volume up button, keep both depressed for about a minute and should reboot.
If that does not work try the corner button and volume DOWN button for the same minute timeframe.
Posted on Jun 15, 2014
Where can I get an instruction guide?
Battery has lost charging capabilities. Time to replace battery.
Since power goes through it first, it feed the device if battery is damaged
Feb 25, 2016 | Tablets & eReaders
I turn my tablet on then it switches it self off
Sounds like it does not have enough battery power to stay on. If you have not tried to charge it, you should try that first. If you have, it sounds like it is not getting charged or not holding a charge. Could be bad AC power source, bad charger, bad charger connection or bad battery. Take steps to confirm that each of these are good. If all of these are good, sometimes the tablet can become so discharged that it will not allow itself to charge. When they are in that state, sometimes you can trick them into charging again by repeatedly disconnecting and reconnecting the charger as follows: With charger plugged in to AC power source, connect the charger to the tablet. Pay attention to the screen or LED or whatever indicator your tablet has to let you know it is charging. You may see it momentarily indicate charging, or maybe not at all. Then unplug the charger from the tablet then immediately plug it back in and pay attention for the charge indication again. You may have to do this a bunch of times (like 20) until you see the indication that it is charging. When you do get the indication, stop unplugging and re-plugging and let the tablet charge for 24 hours (to a full charge). This trick doesn't always work. Sometimes the battery or charging circuit or an internal connection is bad and no amount of unplugging/re-plugging will fix a hardware problem.
Nov 17, 2014 | Tablets & eReaders
How long does it take for the proscan plt 1066 to charge.Why can't I see it charging when the screen goes black?
When you turn off a tablet, it's turned off. Thus, will not automatically illuminate even if it's charging in the background. If you really care to see the battery icon you can press the power button and in some tablets the battery icon will show without necessarily turning on the tablet.
Sep 26, 2014 | Tablets & eReaders
Why has my acer a3 screen gone blank ?
The program of your unit is wiped out. reprogramming is the solution.
Jul 27, 2014 | Acer Iconia A3 10.1 Tablet - 16GB
Galaxy tab 2 10.1 does'nt show thw level ef charge
Try Resetting the Device Cache Partition by booting in to Recovery Mode.
o turn ON in Recovery Mode:
Step 1: Power off device completely (You Might need to Keep it on charge)
Step 2: Press and Hold "power" + "Vol up" for 5 sec
Step 3: Notice it flash boot screen twice
Step 4: Enter recovery menu use vol up and down to navigate
Step 5: Press power button for confirmation
Step 6: Wipe cache partition.
if clearing the cache partition doesn't help, you can also try resetting your device by formatting it to factory settings (ALL DATA WILL BE DELETED). for this Repeat the Steps upto 5, then use Step 6: Wipe data and clear cache.
Post Thanks if it helps
Mar 26, 2014 | Samsung Tablets & eReaders
Black screen
The power cells may be defective and thus the battery will no longer accept a charge. Replace the internal power cells.
Feb 27, 2014 | Motion Computing M1400 Tablet PC
My 7 inch irulu tablet does not charge
Try a different charger that is capable with your device, check battery, or reset if you can. Luck to you
Jan 04, 2013 | Tablets & eReaders
Samsung Galaxy Tab 2 7.0 Logo
54 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
