Question about Exercise & Fitness
I have a proform ce 6.0 elliptical and it has this bump sound it makes in the rear. We have tightened everything we could think of but this sound will not go away
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
You need someone to look at it....call 877-805-1030
Posted on Jan 04, 2014
5 Suggested Answers
  • 103 Answers
SOURCE: Have proform 850 elliptical, unit jerks at bottom of travel
This is caused by a loose crank arm. The key assembly is loose. (#32 on your parts list) The covers will need to be removed to access this. Be sure the crank arms are realigned against the frame when completing the repair. Good luck, Tim
Posted on Nov 13, 2009
ercupa190
  • 12223 Answers
SOURCE: my proform 2605 elliptical the right foot pedal is
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Posted on Nov 30, 2011
ercupa190
  • 12223 Answers
SOURCE: Proform 480 LE Elliptical screen does not work, but everything else works properly
5_3_2012_7_37_07_am.gifclean the contacts batteries for OXIDE, very well, see if some wires is loose.
Try to RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you
Posted on May 03, 2012
ercupa190
  • 12223 Answers
SOURCE: I bought a second hand Proform 14.0 CE elliptical.
FOLLOW this steps and fix it. God bless you
Clean the heart rate monitoring pads if the console is not displaying your heart rate when you grip the pads. Use a damp cloth and a mild soap to clean the pads. Do not use alcohol or any other abrasive cleaners that may damage the equipment.
    • 2
Calibrate the ramp if the elliptical is not functioning properly. Press and hold the "Target Toning Workouts" button on the console until the calibration mode appears on the display. Press the "Target Toning Workouts" button once. The elliptical will display additional directions. Use the "One Step Power Ramp" increase and decrease buttons to raise and lower the ramp.
    • 3
Adjust the reed switch by removing the access cover, which sits over the wheel of the elliptical at the back of the machine. The access cover can be removed with a flat-head screwdriver. Unplug the machine. The reed switch provides information to the console for display. Rotate the pulley until the pulley magnet, which is under the belt, lines up with the reed switch. The reed switch has a wire running into it. Loosen the screw to the reed switch and adjust the distance closer or farther from the pulley magnet. Tighten the screw. Plug in the machine and rotate the pulley. If the console still is not displaying correctly, repeat adjusting the reed switch distance either closer or father from the pulley magnet.
    • 4
Adjust the drive belt if the pedals slip while in use. Unplug the elliptical. Lift the latch on the underside of the left pedal arm and slip it off. Use a screwdriver to remove the arm sleeve and pry open the disc panel. Loosen the pivot screw located on the left side. The belt tighten screw is below the pivot screw. Tighten the belt tightening screw until the belt is tight. Tighten the pivot screw. Replace the disc and arm to the elliptical
Posted on Oct 24, 2013
Right pedal makes clicking noise from the rear of the machine
Remove the right side shield and watch it operate and you'll see what's clicking. You're manual shows you how to remove the right side covering.
Jan 29, 2014 | Proform Pro - Form Rear Elliptical 14.0 CE
I bought a second hand Proform 14.0 CE elliptical. The incline is stuck at about 20 degrees. The incline ramp moves slightly while trying to calibrate but remains about 20 degrees. The display shows that...
    • 2
    • 3
    • 4
Oct 24, 2013 | Exercise & Fitness
Proform hybrid trainer squeaks - elliptical portion only. Everything tight. What do I do now?
Locate the site of the sqeak. Then spray WD40 or similar spray lubricant thoroughly in and around the screws in that area using the straw attachment. I did just that and it took care of the problem.
Aug 07, 2013 | Proform Hybrid Trainer Elliptical
My right pedal makes a popping sound
I'll bet the bolt (one of three) have come off of the threaded plate taking the threads with it. Check the bolts and if one is turning without tightening, that is probably the case. All 3 bolts went on my 395e at once.
Jan 09, 2013 | Proform 395 E Elliptical
I have a proform 14.0 ce and the menu buttons dont work
`1) tight the ribblon cable from keypads very well, + tight the wire connector from display board+vs lower board see the block diagrama
2) adjust the reed swithc, clean, and tigh the connector well.
God bless you
Jun 24, 2012 | Proform Pro - Form Rear Elliptical 14.0 CE
Elliptical is hard to pedal
see the next video:
Apr 30, 2012 | Proform 405 CE - Elliptical Machines &...
I have a 6.0 CE eliptical and the tension is not adjusting it seems to be stuck on very difficult
adjust the magnet, tigh the bolts with some wrench. test the magnet with the magnet from refrigerator for to see if is attracted or repeled , change it if necessary.
Apr 18, 2012 | Proform 6.0 CE Rear Drive Elliptical...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
