Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a Mitsubishi WD52631 that seems to have intermittent problems turning on
Most of the time when I turn the TV on, there will be sound, but no picture. Then after about 10 or 20 seconds it will shut off. But sometimes, the screen will turn on for a few seconds before it shuts off. And then sometimes it will start up with no problems. When it does shut down, I have checked the diagnostic code and it show 34 (Lamp failure). I did replace the lamp about 8 months ago, and since it does work sometimes, I have ruled out the lap itself. Having done some research, it seems to be the Ballast failing. Though I did have the ballast replaced years ago when it was experiencing the overheating problem that seemed to be common with this model. I have been searching for a replacement ballast but every online store with a reasonable price seems to be sold out. Does the ballast seem like a reasonable culprit? And where can I get one cheap? thanks!!
    Problem Solver:
  • 4 Answers
Ballasts were sometimes problems with this set, but I also ran into problems with lamp thermal sensor. It's a small rectangular device sort of cream color and about 1/8th X 3/16th X 3/4 inch in size with lead coming out of one end. Also check safety interlock switch, which is actuated by lamp access cover being properly closed.
Posted on Jan 02, 2014
ctf1800
  • 4402 Answers
SOURCE: Tv Shuts off occasionally 1min upon power up shows red lamp light
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Feb 11, 2008
SOURCE: Mitsubishi WD-52525 Failure
Who needs a repair manual when I have you guys!! Last weekend, my 52525 died almost three years to the day. So rather than throw it away or spend hundreds (not to mention the inconvenience) of dealing with a repair shop - I read your posts. So I dismantled the unit (easily with all the great advice), found the swollen caps, ordered replacements from Mouser, installed, reassembled and the set works perfectly. Also cleaned and realigned the mirrors while it was apart. Like a new TV. Cannot thank you guys enough. Not to mention my family thinks I'm a hero!!
Posted on Mar 22, 2008
  • 146 Answers
SOURCE: wd-52531 has sound, then clicks off after few seconds
It can be the lamp. But the color wheel and ballast can cause the same thing. Put your ear to the back of the set when you push the power button and you should can here the color wheel start up. If not, that is your problem.
Now if the lamp is not lighting up. you should here a ticking sound from the back of the set, if not the ballast is bad. If the lamp is coming on and then going out after only about 5 seconds AND you do not here the start up of the color wheel, the color wheel is confeirmed bad.
Posted on Nov 20, 2008
rob52078
  • 40 Answers
SOURCE: When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Posted on Mar 13, 2009
Slinteriors
  • 8617 Answers
SOURCE: New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Posted on Apr 30, 2009
I have a 40 inch Mitsubishi Lt - 40151 TV. The sound stopped working need some help getting sound going. Will a software update fix this problem?
Problem can be intermittent. In most instances, normal operation can be restored by installing a software update available on-line to the public at Support Mitsubishi TV under the "Support" tab. If this does not correct your problem, double check your setting and make sure the speakers were not turned off. If you are still having problems then you will need to replace the main board, or the pre amp board. Part# 938P103010. I hope this helps.
Feb 15, 2016 | Mitsubishi Televison & Video
Outer screen scratch
Mitsubishi is currently offering the following parts
Model Number Model Description Part Number Part Description Price Available WD-52631 52" DLP TV I/B WD52631 OWNERS GUIDE $15.00 YES WD-52631 52" DLP TV I/QR WD52631 QUICK/REF WD52631/57731/65731 'G' $3.50 YES WD-52631 52" DLP TV 915P049010 LAMP (150W) (V33/V33Y/V33+) 'G' $249.00 YES WD-52631 52" DLP TV 290P137010 REMOTE 'G' $33.10 YES
Mar 27, 2008 | Mitsubishi WD-52631 52" Projection HDTV
No sound at all on Mitsubishi LT-52151. Fixed before by unplugging, waiting 30 seconds, plugging back in. Was occurring more and more often to the point of having to do this every time I would turn it on....
Just fixed this on my TV today! (after 2 months of the sound intermittently failing to turn on and failing completely yesterday) Go to Mitsubishi-tv.com. Go to support. Enter your model number. You will be directed to the documentation for your model which will include a zip file for a firmware update and a PDF file with instructions for installing the update. This fixed my sound.
Mar 02, 2011 | Mitsubishi LT-52151 52 in. LCD HDTV
My Mitsubishi WD-73734 TV will intermittently just shut down- no picture, no sound, the set just turns off. When I check the TV for an "error code," I am able to identify error code # 38. What...
38 Lamp temperature abnormally high. Poor Air Circulation - found in service guide at - http://www.audiolabga.com/pdf/V36-V37-V38_Service_Manual.pdf
Dec 17, 2010 | Mitsubishi WD-73734 73" Television
Sound takes up to an hour to come on, Mitsubishi 35'' tv
A $700 dollar estimate for a sound problem seems out of line - get asecond opinion (did some one look at it or just a guess). If the sound eventually comes on you probably have a connection (internal) problem or a intermittent part in audio section -cap o/p IC.
If you use a satellite or cable box can you hook your sound from that to an audio system thereby bypassing the TV?
Sep 30, 2009 | Mitsubishi CK-35308 35" TV
52" dlp
YOU NEED TO RESET THE TV. USE A PAPER CLIP TO HOLD DOWN THE BUTTON, AFTER THE LIGHT FLASHES FOR ABOUT ONE MINUTE YOU SHOULD BE ABLE TO TURN ON THE TV.
Jun 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi TV air flow
open the back of the television to check for dust buildup on the heat fins and other components. As well as the fan.
Mar 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
DLP Lamp Replacement
yes it is in a cartridge and it is plug and play. and if 1 year old still under wtty. The dimness could also be your fluids??
Apr 01, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
