Question about Tablets & eReaders
Download android os
Security pattern does not work or pattern is lost.
I forgot my applock pattern.please help.
I'm using LEO Privacy. And once I forgot my password, I found their customer service support, they quickly helped me to solve this problem. Fortunately, I did not use factory reset, otherwise all files would be lost. Great app!
Jul 12, 2016 | Samsung 7 Galaxy Tab 4 8GB White
Forgot home screem password for android ipad
How to bypass Android's lock screen pattern, PIN or password
trendblog.net > Guides
Oct 18, 2015 - How to bypass Android's lock screen pattern, PIN or password ..... Hi can anyone help me I have lost my android tablet device in my bedroom ...
How to unlock an Android phone/tablet - How-To - PC Advisor
www.pcadvisor.co.uk > ... > How to unlock an Android phone/tablet
Feb 4, 2013 - But what do you do when you forget your own access code? ... Choose a new screen lock option, such as a pattern or PIN, then enter a code. ... If you've locked your Android smartphone or tablet with a PIN or password, ...
Forgot iPad Screen Lock Password - How to Recover Data ...
www.wondershare.com > Resource > iPhone
Jan 01, 2016 | Tablets & eReaders
Bypass security pattern on a Verizon 4G LTE pad?
Android systems can be full factory reset from the Android System Recovery menu.
For Recovery menu, press and hold the Power On button and some other key (Volume Up, Volume Down, Home ). The combination is different for the different models.
When you are in the Android system recovery menu, use The Volume Up/Down keys for navigation and the Power button for confirmation.
Choose one by one:
- wipe data / factory reset
- Yes -- delete all user data
- reboot system now
Nov 07, 2014 | Pantech Element 4G LTE Android Tablet
TOO MANY PATTERN ATTEMPTS ON SAMSUNG GALAXY GT-P7100
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for google a/c details or security question for pattern lock.
tap forgotten pattern and on next screen enter google account details. Then next screen allows you to choose a new screen lock option.
Otherwise for a factory reset use recovery mode
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
Aug 07, 2014 | Samsung Galaxy Tab 101 Tablet...
I forgot my parten to unlock my tablet which is running android os 4.0 help me please
If you use the wrong pattern often enough, Android will ask you to login to the tablet using your Google ID and password (the one you use for Gmail and your calendar). This should allow you to access the tablet and from there you can set a new pattern.
Jul 03, 2014 | Tablets & eReaders
Forgot my password to get into my android table MID M729 the pattern on the top of the tablet
Normally, with Android devices, if you enter the wrong pattern five times in a row, the device will give you an option to enter your Google account information (e-mail address and password). Once you have done this, it will let you reset your security pattern.
If this doesn't work, the next best thing to try would be a firemware The firmware update process will wipe the root of the device (but leave your SD card and books intact), basically resetting it to factory settings, before you even set a security pattern.
Should this fail to work, contact Velocity Micro Support by calling +94756523353
Dec 28, 2012 | mid Archos M729B Android Tablet
I have an Evorea Tablet, I power up get a white screen but no home buttons show up, in fact nothing but a white screen
Hello Jachin, if you still have this problem. Try doing a "hard reset"
- Turn off tablet
- Hold down the power and volume "down" key together
- when red text appears select "yes" by holding down power key for 10 secs.
Reformatting shall commence
Please note that this process works on most android tablets.
Hope this helps
Nov 24, 2012 | Android Tablets & eReaders
Where can i download free anti virus for my ipad tablet
The best 2 choices are Avira and Avast -
If you need it for a Mac OS ipad tablet then here are the 2 links:
1. http://www.avira.com/en/download-start/product/avira-free-mac-security
2. http://www.avast.com/free-antivirus-mac
If you need it for an Android OS tablet then here are the 2 links:
1. http://www.avira.com/en/avira-free-android-security
2. http://www.avast.com/free-mobile-security
May 18, 2012 | Tablets & eReaders
Tablets & eReaders Logo
65 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
