Question about Texas Instruments Office Equipment & Supplies
Ti81 will not start
Is there a reset or something I can do to test this
  • Texas Instru... Master
  • 8,073 Answers
If it has a hardware reset button you should see it on the back of the calculator.
First thing to do is replace batteries with fresh ones after cleaning the metallic contacts.
Second thing is to increase contrast.
Posted on Jan 02, 2014
2001Toyota Rav4L 1AZ FSE won't start test crank and cam sensor good high pressure pump good no pulse from the injecter wire using pulse light could you tell what's wrong.
No pulse means computer is not getting something it wants. Do you have spark at plugs? Correct fuel pressure? Security system needs reset?
Mar 19, 2016 | Cars & Trucks
Tip
Reset procedure of Waste Ink Tank for Canon MP390 and Canon MP360
<p><span>Manual Reset procedure Waste Ink Tank for Canon MP390 and Canon MP360 Just Follow these steps to reset waste ink tank:</span><br /> <p><span>Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.</span><br /> <p><span>Select Test mode which is like the last available selection</span><br /> <p><span>Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button</span><br /> <p><span><span>&middot;<span> </span></span></span><span>The menu will now say EEPROM Clear</span><br /> <p><span><span>&middot;<span> </span></span></span><span>Select Ink count which is option (0) and press set</span><br /> <p><span><span>&middot;<span> </span></span></span><span>Then press Stop/Reset Followed by the power button and then wait for it to restart.</span><br />
on Nov 28, 2010 | Computers & Internet
Where is reset button lacated
For what?
Where do you & thousands of others
come up with this stuff about reset buttons
on vehicles
If you had to charge the battery-- it failed for a reason
What was it ?
How old is the battery?
Was it tested?
If not-- there may be your problem
You can't just say it won't start-we can't help
You may never work on vehicles or know how to
You have to tell us what was tested & how
Where is the car,in a shop,your working on it
& need to know something?
Starter is out & at parts store to be tested?
Have to give us something to work with
Sep 28, 2014 | 1998 BMW 7 Series
Where to buy instruction manual for Texas Instrument TI81 #0259234
If you can live with an electronic copy which you may print here is the link. It is free.
Jul 14, 2012 | Texas Instruments TI-Nspire Graphic...
My explorer keeps stopping when I am in the middle of something
Try to reset Internet Explorer using these steps
Open Internet Explorer
Click Tools > Internet Options (if the menubar is not visible, press Alt key)
Click the Advanced tab.
Under Reset Internet Explorer settings, click Reset. Then click Reset again.
When Internet Explorer finishes resetting the settings, click Close in the Reset Internet Explorer Settings dialog box.
Start Internet Explorer again, test the issue.
Oct 15, 2011 | Toshiba Satellite L505-S5966 Notebook
Can I find the cubic root using my TI-81 calculator?
There's a cube root function in the MATH menu. As an example, to calculate the cube root of 125, press MATH 4 1 2 5 ENTER .
Sep 16, 2011 | Office Equipment & Supplies
How do I put an absolute value in the TI81
2nd [abs] (the (-) key). For example, to take the absolute value of -1.2, press
2nd [abs] (-) 1 . 2 ENTER
Jan 28, 2011 | Texas Instruments TI-81 Calculator
How do you reset airbag light for 2007 elantra
The airbag light is reset using a scan tool. most of these systems reset them selfs unless it sees a system failure on power up, the airbag system tests all components of the sirbag system every time you start car and if something is wrong it will leave light on, you will need to scan the computer for codes the codes will tell you what the problem is and with some testing the problem can be found.
Dec 08, 2010 | 1997 Hyundai Elantra
I want to connect the calc to my computer. I have the connecting cable but not software. Can I download from somewhere?
Any connectivity software for the Yexas Instruments cakculators is downloadable from the TI Support web site. Among the various versions available, I have not seen any relating to the TI81. However, it is possible that the TI Connect software can be used. I do not vouch for that. I have no TI81 to test it on.
Here is the link for all available connectivity software . If none works for you, I suggest you visit the ticalc.org archives. You might be lucky.
Hope it works
Nov 24, 2009 | Texas Instruments TI-81 Calculator
22 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
