Question about Razor Dirt Quad Bike
Rear sprocket turns but Back wheel is unresponsive
2 Suggested Answers
SOURCE: Chain & Sprocket turn, but Rear Wheel Not engaging/spinning
The problem is witht he flywheel on the rear wheel assembly. I had mine fixed by a professional last night (at a bike store). Razor uses a very cheap spring that is designed to fail and then to top that off did not use enough bearings as well (12 bearings short out of the factory). My son had also sprayed WD-40 all around the back axle (trying to make it faster). This is bad because, the bearings are packed in grease and WD-40 is a de-greaser. Never get WD-40 anywhere near your back axle!!! Anyway, the flywheel was way easier to remove than I thought. It is threaded onto the rim's axle shaft and just screws off. Once you get the flywheel, off you have to take it apart, fabricate a new spring (my son's new spring came from an old 10 speed's tensioning spring), reset the 3 pawls, repack the bearings, put the flywheel back together, and screw it back onto the wheel. I will post a YouTube video on this later. Hopefully this is enough info to get you started.
Posted on Nov 03, 2010
2008 harley road glide rear wheel does not tuen
If the rear sprocket turns but not the wheel then the sprocket fasteners could not be securing the sprocket to the hub and you must have sheared sprocket bolts.
Sep 29, 2014 | 2009 Harley Davidson Road Glide CVO Base
The pedals will turn but the wheel does not
The rear set of gears, called the "Freewheel" are shot, and need to be replaced. You can find another wheel, but this will probably prove to be difficult, or you can pay for a new freewheel or your bike shop may give you an old one for a discount.
Good luck
Joe
Aug 29, 2011 | Cycling
Rear sprocket slips when chain is on the smallest sprockets. when I shift to the two largest sprockets on the back wheel, it peddels or ingages fine
Sprockets are all connected and turn together as a unit. The chain could be skipping over the teeth on individual sprockets.
I suspect severe chain and sprocket wear.
http://sheldonbrown.com/chains.html
Jul 10, 2011 | Cycling
Chain is turning but the rear wheel is not moving
What??? RLtoFixYa doesn't know what they are talking about. Your problem is a faulty/broke "one way roller clutch" which is threaded onto the rear wheel. I've already replaced 2 on my son's MX500.....
May 25, 2011 | Razor MX500 Dirt Rocket
The sprocket on the rear wheel is frozen. The bike cannot coast as the petals keep turning when the rear wheel is turning.
If I were fixing this problem, the first thing I would do is soak the sprocket with WD-40 or CRC. After a day, gently tap the sprocket in an attempt to free it. Soak it again and so forth. If it doesn't come free in a few days, it may be better to replace it. What condition is the chain in of the rear sprocket is frozen to the wheel?
Thanks for your interest in FixYa.com
Feb 10, 2011 | Cycling
When shutting down throttle in gear, a heavy clonk is felt through transmission! chain and sprockets good.! thankyou.
If the chain and sprockets are in good condition and adjusted properly ( 1 1/2" slack ), you should check the rear wheel sprocket dampers. These are made of rubber and can deteriorate over time. If the dampers are bad you will be able to move the rear sprocket forward and back while the bike is sitting still. It is an easy fix to replace them, just remove the rear wheel and sprocket. they are model specific parts and should be available from your local dealer.
Steve
Jan 02, 2011 | 1993 Honda CBR 1000 F
I had to take off the rear weel of my falcon apache mountain bike to get it in my car o travel from my grandparens home to mine but i cant get the back weel gear arm back on. how do i do this??
By the "gear arm" I assume you mean that part of the rear derailer that the chain zig-zags through. This arm moves in two ways. It moves in and out (toward the wheel and away) as you move the shift lever - which is how it changes gears, by moving the chain onto different sprockets (gears). It also moves forward and back (toward the front and back of the bike) under spring pressure. This forward and back motion is necessary to take up the slack in the chain when you are using the smaller sprockets (the smaller the sprocket, the "higher" the gear). When the wheel has been removed, this arm moves forward (under spring pressure) as far as it can to take up all of the slack in the chain. All you have to do is grasp this lever and pull it toward the back of the bike, allowing the lever and the chain to pass behind the sprockets (gears) as you pull the wheel back into it's position. You can safely pull this arm forward and back at any time without doing any damage. One more tip-- I find it a little easier if you first put the shift lever in a "middle" gear position. Then when you pull the wheel into place, you should aim to put the chain on a middle sprocket. You don't have to hit the exact correct sprocket as you can simply lift the rear wheel and turn the pedals forward (after installing the wheel) and the chain will move to the correct sprocket corresponding to the setting on the shift lever.
Good luck! Please vote if you found this helpful. Al K
Oct 14, 2010 | Falcon Cycling
Rear wheel won't turn when pedaling
hi there,
put your bicyles on upside down position,wheel should on top so you can work freelywork on ,then rotate the pedal to check what the problem it should be freely rotating,check break pads if it was engage even w/o pressing control.release brake cable wire to loosen.if not in the break,check the sprocket gear if connecting to the chain belt,check your sprocket release lock,if damage replace sprocket, check the bearing of the two wheel center shafting if worn out replace bearing,on front wheel there are two quick release nuts,loosen and pull out wheel and loosen all nuts and lock plate bearing,pull out shafting with the bearing,examine mostly bearing worn out also shafting in some occasion its worn out also,possible if you want replace one set center shafting and bearing ts not costly,on rear wheel with sprocket it different to disconnect,beacause there is sprocket,you should dismantle the locked plate and lock nuts of sprocket before the shafting assymble same procedure now on front wheel when after disconnecting sprocket on rear wheel.hope this will guide you and solved your problem have anice day.
Jul 14, 2009 | Mongoose Cycling
Drive chain goes loose and tight on back wheel turn
No.That was the problem.The chain and the sprockets needed to be renewed.
When you will take, the rear sprocket's base, off the axle check it's bearing.Just put your finger in and turn it slowly to see if it "locks" instantly.It will be nice if you renew it now that you disassembling the chain drive system.
Jun 07, 2009 | 2002 Honda CBR 600 F(4)i
May 10, 2009 | Razor MX500 Dirt Rocket
Razor Dirt Quad Bike Logo
Top Razor Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
RatanbssBD
Level 1 Expert
Are you a Razor Rock and Ice Climbing Expert? Answer questions, earn points and help others
