Question about Wolfgang Puck Electric Pressure Cooker Slow Cooker
I am using my pressure cooker for the second time. It is not getting up to pressure and it is making a whistling sound. What is the problem
  • 190 Answers
Remove the lid and make sure the gasket is in the right place. Then place the lid on again, and make sure the pressure valve is set to closed.
Here are the Wolfgang Puck manuals, if you're lacking one. Also on that website a great place to ask any basic pressure cooking questions.
http://www.hippressurecooking.com/category/manuals/wolfgang-puck-hsn/
Posted on Jan 02, 2014
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
Cooker manual needed for philippe richard 8 qt pressure cooker
I purchased a Philippe Richard 6 qt pressure cooker and the second time I used it I noticed steam venting out of the pressure handle lock. later I stepped on something in the floor. it was the aluminum part for the pressure lock. I didassembled the handle but don't know how to get the part back in place, please advise. thank you
Russell Johnson
Ozark, Arkansas
Dec 30, 2011 | Crock Pots & Slow Cookers
I do NOT know how to use i.e keep at pressure without burning stuff. This is my daughter's Sambonet pressure cooker, it has a strange looking style of lid lock down that is part of the pressurisation...
Pressure cookers rely on pressure and steam,
Do a dry run first...well not dry but with just water, (no food) especially if it's an old cooker.
Inspect for cracks or pinholes before you go ahead, a crack ANYWHERE in a pressure cooker makes it a bomb...or a flower pot.
Ensure all safety devices like the pressure regulator and blow out plug are in good condition and not plugged.
If some previous owner replaced the blow out plug with a bolt or something silly don't use the cooker till it's repaired.
Bring your pressure cooker slowly up to pressure over medium heat with an inch or two of water in the bottom.
When it starts to vent steam turn the heat down so the steam barely escapes, if it has a rocker weight it will wobble a couple times a minute.
Slow gentle heat is the trick. A cooker will run for hours like that without boiling dry.
A couple tips, use salt and spice sparingly, it's trapped in there and permeates the food.
Be careful with foods that expand on cooking like rice and dried things, they can get up and block the vents if they reach the lid.
TickMagnet
Jul 22, 2011 | Presto 01282 Aluminum Pressure Cooker Slow...
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Can i cook spaghetti in the pressure cooker
I have not tried spagehetti but i do cook macironi in there.
i use 2 cups of pasta.. macironi or shells. 1 cup water and 1 cup milk.. then 1 cup shredded cheese. 1 table spoon of butter.and 1 table spoon of olive oil i select rice and add time until it gets ot 10 min.
then i have macironi and cheese.
i also make pasta with tomato sauce in there.
again 2 cups pata shelles.. 1 can of tomato sauce, some choped onions.. 1 cup ground beef. and 1 cup of water. set cooker for 10 min ..
Apr 02, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
E4 on the Woldgang Puck Electric Pressure Cooker
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Mar 18, 2009 | Wolfgang Puck Electric Pressure Cooker...
E4 error....What is this?
before using the pressure cooker make sure the bottom of the container is dry.. I got this error then i just wiped of the bottom of the inner container.. turned off the pressure cooker then turned it on again.. it worked fine after that.. no more error.
you also want to make sure, when you use the cooker you have at least 1 cup of liquid in the cooker .. the measure cup that comes with cooker
Oct 25, 2008 | Wolfgang Puck 5-Quart Electronic Pressure...
Ultrex pressure cooker model innova 14240
Pressure cookers are only slightly more complicated than crock pots. In fact, you can think of them as the opposite of Crock pots. Where a crock pot needs 2-3 times as long to cook something, the pressure cooker needs only 1/2 to 1/3 of the time.
These are not that complicated and haven't changed in the last 50 years. The only real hard part is being sure is doesn't explode; not that hard: don't cook things that would foam, like pasta or potatoes. Just read some recipes on the internet or get a recipe book at a bookstore, used book store (super-cheap)or the library. My best advice is to make sure you use the lowest possible heat that still allows steam to escape at a whisper. That will keep things from burning (or scorching) on the bottom, which can give a harsh taste and make clean-up more work. Just do it.
Jul 20, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
Wolfgang Puck Electric Pressure Cooker Slow Cooker Logo
175 people viewed this question
Top Wolfgang Puck Crock Pots & Slow Cookers Experts
Sloop Johnb
Are you a Wolfgang Puck Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
