Question about 2004 Mustang Factory Wiring Diagrams
How to replace a fuel temperature sensor on 2003 hyundai sonota
I need to find out how to get to a fuel pump on a 2003 hyundai sonota
  • 4 Answers
If im not mistaken theres an access panel under the rear seat. Take thecover out and you should be able to see the fuel pump.
Posted on Jan 03, 2014
How to replace a fuel temperature sensor on a 2003 hyundai sonota
make friend with a korean on facebook and ask him/her a favor
Jan 01, 2014 | 2004 Mustang Factory Wiring Diagrams
2003 Hyundai Sonata fuel pump fuse located
Need a picture of where to find the fuel relay switch on a 2003 Hyundia sonota
May 12, 2012 | 2000 Hyundai Sonata
Dont know how to change air intake sensor on 2000 hyundai sonota 6 cyl..... Think they might have gave us the wrong part????
THE INTAKE AIR TEMPERATURE SENSOR IS MOUNTED IN THE INTAKE AIR HOSE OF THE AIR CLEANER .THE INTAKE AIR TEMPERATURE SENSOR IS INTEGRATED INSIDE THE MASS AIR FLOW SENSOR.SHOULD BE NO PROBLEM REMOVE.DISCONNECT ELECTRICAL CONNECTOR,THEN REMOVE THE MOUNTING SCREWS HOLDING IT IN PLACE.THEN REMOVE IT.TAKE THE OLD INTAKE AIR TEMPERATURE SENSOR WITH YOU TO THE AUTO PARTS STORE SO THEY WILL MATCH UP AND GIVE YOU THE CORRECT SENSOR.WHEN YOU INSTALL NEW SENSOR,YOU NEED A CODE SCANNER TO ERASE CODE TO TURN OFF CHECK ENGINE LIGHT.
Feb 20, 2011 | 2000 Hyundai Sonata
I have a 2003 hyundai XG350 its really hard to start after it sits 10 mins or longer. Had dealer check it out. they said all the sensors are OK they replaced the fuel pump 3 times still the same problem....
First and foremost, has anyone VERIFIED that the CAUSE is the fuel pump? Hard starting has NUMEROUS possible causes -- wiring, connectors, sensors (MAF, MAP, TPS, APS, ETS Motor, IAT, ECT, CKP, CMP, etc.), injectors, timing, air flow, fuel pressure, contaminated fuel, vacuum leaks, Powertrain Control Module (PCM - garbage in memory - adaptives), The more sofisticated the technology, the more COMPLEX the diagnosis. It seems you have an INTERMITTENT malfunction in one (or more) EMS (Engine Management System) components. The only way to diagnosis this is when that particular component acts up! My first suspicion is the MAF (Mass Air Flow Sensor w/Intake Air Temperature Sensor-IAT and/or the Engine Coolant Temperature (ECT) sensor. The possibility also exists that the technician who examined/inspected your vehicle wasn't the swiftest of mechanics - meaning he/she didn't fully understand what they were looking at/testing. Hyundai Shop Manuals aren't the best either. There's no possible way for me to DIAGNOSE your problem without PHYSICALLY examining your vehicle. SEVERAL SOLUTIONS: You can educate yourself regarding the systems installed on your vehicle & attempt to fix it yourself -- Go to http://www.hmaservice.com/ and register (vehicle by VIN). Afterward, you'll have access to technical information (manuals, wiring diagrams, service bulletins, etc) about your vehicle. OR, you can take the vehicle back to the Hyundai Service Center (dealership), and tell them to FIX IT! OR, hire an attorney & file a lawsuit. The latter being the last resort.
Feb 26, 2009 | Hyundai Motor 2003 XG350
Fuel pump relay
usually located in the main fuse box under hood
Jan 23, 2009 | 2006 Hyundai Sonata
Replacement of 2003 hyundai sonota instrument cluster
Removed the dash bezzle and low and behold there were the screws to remove the dash cluster
Jan 20, 2009 | Hyundai Motor 2003 Sonata
My 2006 Hyundai Sonota Will Not Start!
could be the fuel pump
how ever my advice
the car should be under warranty
take it to Hyundai and have them fix it
there should be no cost to you
Dec 27, 2008 | 2006 Hyundai Sonata
FUELING CAR DIFFICULT
If your ck engine light isn't throwing a e-vap code don't mess with your canister unless you pull the vac line off an gas poors out of it.Reposition your nozzle an pump slower this is common with many cars.Save your money.
Nov 16, 2008 | Hyundai Motor 2003 Sonata
Anti roll over switch, 2003 sonata, where is it?
the 2003 sonota does not have a roll over switch. It has what is called a roll over valve and is located near the fuel pump. It will not cause any issues as it is self reseting and needs no maintance or replacement
Oct 07, 2008 | Hyundai Motor 2003 Sonata
2004 Mustang Factory Wiring Diagrams Logo
85 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
