Broken cable connection BN41-01149A
The screw on plug for cable connection was pulled from unit
2 Suggested Answers
  • 112 Answers
SOURCE: I pulled out the cable plug from the tv unit where
The threaded core that was pulled off the main board might be repairable. It just depends on what the tuner on the main board looks like now. However, It may be too bad to repair.
Keep in mind, if a shop does solder the core back on… it will not be as strong and it could easily break off again. Also, the repair shop may charge you almost as much as a new board for this type of repair.
The best way to repair your TV is to get a new main board.
I can get you the part number if you need it. Good Luck.
Posted on May 18, 2010
Panasonic photocoppier 8016 err0r for u16 p/m kit please reply fast
u 16 usually refers to no developer installed. Open the front door and remove the waste container. Remove 1 screw and remove developer connector cover. Make sure plug id properly inserted. 2. Open side door loosen screw on drum developer unit on the front and pull drum developer unit out to the front of the machine. There is a small cable and plug on the developer unit close to the front spring. Make sure it is properly connected
Oct 15, 2013 | Panasonic WORKiO DP-8016 Printer
Needinstruction on replacing window on 2000 jaquar s type
Windows do not come of any track
The window regulator that puts it up &
down has broken
Remove the inner door panel & you will
see the issue
Replace the broken assy,do not try &
piece it back together
Other than finding door removal instructions,
your on your own ,once inside the door
Try You Tube Video-- may get lucky & can
watch what you need to do yourself
Jan 24, 2013 | 2000 Jaguar S-Type
I have an rca hdlp6iw51 and i found a color wheel on ebay but i dont know how to change it does anyone have any advice
Follow this steps:
1. Take the back panel off of your set, using your Phillips head screwdriver, to remove any screws. 2. Remove the projector lamp. You can reach the color wheel without doing it, but you are less likely to damage the projector lamp if you take it out. Loosen the screws at the base: depending on your DLP's brand, the screws may come out, or may just loosen. If they come out, set them in a safe place before removing the lamp. If not, just pull the entire lamp out, once the screws will not loosen further. 3. Take out the panel that is connected to the cable outlets, using the screwdriver to take out any screws. Pull the panel until the cables, attached from the inside, run out of slack.
4. Remove the screws at the bottom of the panel, in the center, and any screws connecting this panel to the outer case of your DLP. The number and location of these screws will vary depending on your DLP's brand.
  • 3 Remove the projector lamp. You can reach the color wheel without doing it, but you are less likely to damage the projector lamp if you take it out. Loosen the screws at the base: depending on your DLP's brand, the screws may come out, or may just loosen. If they come out, set them in a safe place before removing the lamp. If not, just pull the entire lamp out, once the screws will not loosen further.
  • 4 Take out the panel that is connected to the cable outlets, using the screwdriver to take out any screws. Pull the panel until the cables, attached from the inside, run out of slack.
  • 5 Remove the screws at the bottom of the panel, in the center, and any screws connecting this panel to the outer case of your DLP. The number and location of these screws will vary depending on your DLP's brand.
  • 6 Pull out the entire center unit, pulling gradually. Then, unplug the power cable from the main set (this is generally blue and brown). Remove the sensor switch and any cables joining the center unit to either side of the set.
  • 7 Take out the plug from the cover of the color wheel. In most brands, it will have a black and blue wire connected to a green circuit board. Then, remove any cables coming out of the wheel. Depending on the brand, the screws may be small enough to require the jeweler's screwdriver.
  • 8 Remove the screws holding the color wheel cover in place. Remove the cover, then take out the screws holding the wheel in place. If tape is holding the wheel, just pull on the wheel until it comes free.
  • 9 Put the new wheel into the slot. You do not want to touch the wheel, or you will blemish it and leave impressions that will be visible when the light shines through it. Re-insert the screws. Then, replace the cover, making sure that the wire jacks are in the same places.
  • 10 Reassemble the DLP television, then plug the set into the wall, and turn on the power.
  • Read more: How to Change a DLP Color Wheel ' eHow.com http://www.ehow.com/how_7697815_change-dlp-color-wheel.html#ixzz1VdDl2OQb
    Aug 21, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
    When I flip my acer aspire 4315 screen it goes white.
    A laptop display is one of the most expensive single parts to replace. It can be frightening to try to boot up your Acer Aspire one day and have it display only a white screen. Unless the screen itself has been broken, the cable between the laptop and the screen has either become disconnected or broken. This is a relatively cheap repair.
    Disassembly
    1.Disconnect the unit from AC power and remove the battery. This can be done by flipping the unit over, pressing the latch on the bottom of the unit and then pulling the battery away.
    2.Remove the two screws revealed by removing the battery. Remove two additional screws set into the corners of the base on the edge where the battery was.
    3.Turn the laptop over and open the lid. Remove the panel with the power button on it by gently pulling up from the top edge. Remove the keyboard by gently pulling at its top edge to release the four catches on the sides. Once it is free of the catches, flip the keyboard over and lay it down. If you wish, you can disconnect the ribbon cable leading to it and set the keyboard aside.
    4.Unplug the video cable. The video cable is the thick wire coming out of the left hinge of the LCD. It is gray and rounded. The cable terminates in a rectangular plug that goes through the top of the laptop base.
    5.Turn your attention to the LCD. Remove the rubber feet at each of the corners of the LCD. Remove the four screws that are revealed.
    6.Pull the LCD bezel (the plastic part that surrounds the screen) away from the lid by starting at the top and pulling up and away from the inside with a rolling motion. The bezel is secured by plastic latches all around the outside, and pulling up with a rolling motion is the best way to get them to release without breaking. You can also take your blade or screwdriver and insert it between sections of separated lid and bezel to hold them apart and prevent re-latching. Be careful and patient with this step. Believe it or not, this is where the majority of laptop damage is likely to occur.
    7.Remove the two cables connecting the inverter board to the LCD screen and the video cable.
    8.Remove the four final screws holding the LCD panel into the lid. Two are at the bottom corners, just above and toward the center from the hinges. The other two are at the top center, holding the webcam and LCD to the lid. You should now be able to pull the LCD out of the lid and lay it face down on the base of the laptop.
    9.Remove any tape securing the LCD cable gently, and then tug the cable out of its socket and set it aside.
    Replacement and Reassembly
    1.Begin by gently inserting the replacement video cable into the socket on the back of the LCD and re-securing the cable with the same tape from earlier. Lift the LCD back into the lid and screw the panel back into place. Finally, re-connect the two cables to the inverter board.
    2.Press the bezel back into place with a firm, but not overwhelming, pressure. Each section should "click" when the latch engages and not separate again without effort. Replace the screws holding the bezel in place and then re-cover the screws with the rubber feet.
    3.Plug the new video cable into the main board. Use a gentle and even pressure, making sure that everything is lined up. If you disconnected the keyboard, reconnect it and push it gently back into place until the catches reengage. Place the power-button panel back in place and press it down before closing the lid and flipping the laptop over.
    4.Replace the four remaining screws and slide the battery back into place. Reconnect the laptop to AC power and turn it on. Your screen should now be functioning normally again!
    I hope you find it very helpful. Best regards.
    Aug 18, 2011 | Acer Aspire 3690-2196 Notebook
    Heater only works on #1 setting after I replaced resitor pack
    resistor is working but switch is bad. You can get a new switch from autozone for $20. Here is autozone procedure for pulling the control panel. Let me know if you have questions.
    1. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
    2. Remove or disconnect the following:
      Audio unit Instrument panel console bezel retaining screws
    3. Pull the instrument panel console bezel forwards and disconnect the electrical connectors.
    4. Detach the temperature and air distribution blend door Bowden cables from the climate control assembly.
    5. Remove the climate control assembly.
    To install:
    1. Install or connect the following:
      Climate control assembly Bowden cables to climate control assembly Climate control assembly electrical connectors Instrument panel console bezel and securely tighten the screws Audio unit Negative battery cable
    Dec 16, 2010 | 2000 Ford Focus
    The screen is broken no take pitchure
    Remove the battery. Remove the case screws and pull the case apart. Where the flat ribbon cables connect to the main board, carefully release the clamps on the board end plugs. The plugs don't come off, the ribbon just comes out of them. Carefully remove the screen. It has double stick foam in a few spots. Put the new screen in, reconnect the ribbon cables and put the case back together. 30 minutes max.
    Apr 01, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
    Always says bad disk on display when you try to play a dvd
    Remove top cover (5 screws) and load a DVD while looking under the top of the drive for the red light. If you don't see the red laser light, remove the DVD and turn the unit off. Remove the plastic 1" bar that goes across the top of the drive (2 screws). Pull out the flex cable going to the light and plug it back in. Unplug the other end of the flex cable where it plugs into the motherboard and plug it back in. This fixed mine. It was just a bad connection in the flex cable to the red light laser.
    Jan 11, 2010 | Toshiba XD-E500 DVD Player
    How do I get to the drivers side light bulb in a 2006 Chrysler Sebring Sedan? I have the replacement bulb and want to change it myself.
    I will assume you are talking about the headlight?!
    Removal
    CAUTION: do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced life will result.
    1) Disconnect and isolate negative battery cable.
    2) Remove headlamp unit retaining screws. (bolts)
    3) Remove headlamp unit to expose back of unit.
    4) Disconnect wire connector from back of headlamp bulb.
    5) Rotate retaining ring counterclockwise.
    6) Remove retaining ring.
    7) Pull headlamp bulb and remove from headlamp unit.
    Installation
    1) Install headlamp bulb to the headlamp unit.
    2) Install headlamp bulb retaining ring.
    3) Rotate retaining ring clockwise.
    4) Connect wire connector to bulb.
    5) Install headlamp unit.
    6) Install headlamp retaining screws. (bolts)
    7) Connect the battery negative cable.
    More detailed info on how to get unit out.
    Removal
    1) Disconnect and isolate the battery negative cable.
    2) Remove the two retaining screws.
    3) Remove the upper fascia retainers by prying under the head of the fasteners with a flat bladed tool.
    4) Remove headlamp unit from fender side first, then pull headlamp unit out.
    5) Disconnect the wiring harness from the bulbs.
    6) Remove the headlamp unit.
    Installation
    1) Connect wire harness to the bulbs.
    2) Install headlamp unit.
    3) Install the retaining screws.
    4) Install upper fascia retainers.
    5) Connect the battery negative cable.
    I hope this will help you to get the light changed.
    Jan 11, 2010 | 2006 Chrysler Sebring
    My cable connector pulled out from the tv and now the tv won't stay on the power button will blank three times and go off what can be the problem?
    when the cable got pulled it broke a connection on the board , and thatswhy it won't come on
    it will need to be resoldered where the cable was pulled
    need more help just ask me!
    electech
    Oct 26, 2008 | RCA Televison & Video
    Brother MFC 8440
    on one rear corner is a cover held on by one screw, this opens up the compartment that has all the connections from top unit to bottom, there are scewered in earth cables about 8 plugs, two ribbon cables, all need to be removed, some go on to a board hidden by a h shaped plate, so unscrew that as well, some also go to a larger board below corner, side of machine slides back, to reveal another metal box that two more screws to open.
    Once all cables are detached and you noticed which one went where, take pics! Two screws come off the posts that secure adf to scanner then whole unit slides up and off.
    Becarefull to get all cables reattached and in correct sockets
    If you just go for it and pull apart the wrecked machine and reomve its adf then you know you are ok to attack the good one
    Jan 02, 2008 | Brother MFC-8440 All-In-One Laser Printer
    Televison & Video Logo
    21 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
