Question about Dell Computers & Internet
Power supply board defect
I have a Dell 2007FPb lcd monitor that won't power up. I found a series of posts and a link to a parts source for a replacement power suplly board. Wouldn't you know, can't find it again! any ideas?
  • 191 Answers
Hi there, you may consider:
1) you may check what parts damage on the power supply board, such as if you find any big capacitor swelled, you can fix it yourself
2) if you can not fix the board, you may check follow webste choose a same one or contact to seller to make sure the parts whether compatible yours.
http://shop.ebay.ca/items/__Dell-power-board_W0QQ_kwZDellQQ_kwZpowerQQ_kwZboardQQ_ckwZmonitor?_trksid=p3286.m104.l1200
hope help you fix it, send any question to me please. take a rating let me know how much helped you thanks!
Posted on May 20, 2009
Dell stuck in power safe mode
A blinking power light is not indicating power safe mode, it indicates a failure of the power supply board in the monitor. Here is a link to repair guides that show how to open and repair the power supply boards in the Dell E173 series of monitors;
http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/
I hope this helps,
Apr 08, 2012 | Dell E173FP 17" LCD Monitor
I HAVE DELL LCD TV SCREEN 2007FPB SUDDENLY IT DOES NOT WORK WHEN CONNECTEC TO POWER SUPPLY, PREVIOUSLY IS GOOD WHAT IS THE PROBLEM & HOW MUCH MONEY NEED
First check your monitor light is blinking or not. If it is then--
Check your monitor cable which is connected your CPU. If it is ok then
Open your CPU and unplug *********** board power cable and re-install it.
And also remove RAM and clean with a brush softly and re-install it.
Best of Luck
May 13, 2011 | Dell E173FP 17" LCD Monitor
CAN'T GET THE MONITOR OUT OF POWER SAVING MODE
If you have a blinking power light and no display even when you first power up the unit then its not in power saving mode. The blinking power light indicates a failure of the filter capacitors on the power supply board. This is a very common problem with LCD monitors after a few years of service. The power supply can be repaired by just replacing the defective filter capacitors. Here is a picture of the power supply board with the bad caps circled in yellow and below that is a link to a full repair guide showing how to open the unit and what to replace including a full parts list.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
I hope this helps you out,
BuddyMc
Feb 11, 2011 | Dell UltraSharp 1905FP 19" LCD Monitor
My Dell E153FPc 15" shuts
Look for cold solder joints, shorted transistors, bad fuse, bad caps.
See pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E153FPB/
Replacement board: http://www.lcdrepair.us
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Feb 02, 2011 | Dell E153FPc 15" TFT LCD Flat Panel...
BLINKING GREEN LIGHT
You have shorted out transistors in the backlight inverter circuits.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
http://www.electronicrepairguide.com/dell-E153Fpc-lcd-monitor-repair.html
May 30, 2010 | Dell E153FP 15" LCD Monitor
E177FPc dell lcd no power and no display
May 23, 2010 | Computers & Internet
Where can I buy a power supply for an AOC LCD monitor model TFT 1780?
hi, i don't know if you will ever find just the power supply board for this monitor. i repair lcd monitors for a side business and i have never found the exact power board i needed for any of the monitors except for dell 17in. you would have to look on ebay for another broken monitor just like your with a working power board, broken screen maybe. that being said, why do you think you need a power board complete? the parts on the board are replaceable. maybe you could post a reply so i can read to help with what the symptoms are and help you diagnose the problem components? if you posted pictures in your reply of both sides of the board, it might help me describe more in depth.
Mar 08, 2010 | AOC 1780 (Beige) 17 in. Flat Panel LCD...
Broken plastic power button
Broken plastic power button? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1742SED2H 715G1492 2 FR Dell ADTV1742SED2H Power Supply Backlight Inverter...
Apr 29, 2009 | Dell E177FP LCD Monitor
No power
check your powers suplly waltage and earthing properly.change your power cable of lcd monitor.
reconect it.fix it proerly.then try u can do it.
Feb 09, 2009 | Dell E153FP 15" LCD Monitor
Computers & Internet Logo
881 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
