Question about Toshiba E-Studio 306 Copy Machine
Wont copy..job status flashing bypass tray flashing
Someone put thick paper in it and now it wont print
SOURCE: Toshiba 281C Bypass tray
Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
Posted on Feb 18, 2009
  • 76 Answers
SOURCE: how do i get the bypass feeder to start printing
put the paper in the bypass and select paper type.
Posted on Oct 06, 2009
M2Tech1
  • 313 Answers
SOURCE: E-Studio 3511 will not print a3
check to make sure on the display panel the paper tray is showing A3 PAPER SIZE>> the paper size indication should match up to what is in the trays if not the machine will be asking for A3. Also try putting in another tray to see if there is a fault with the paper tray .. if it works with other paper sizes it may just be the size hasnt been set properly for that tray.. Hope this helps A
Posted on Jan 18, 2010
nonontech
  • 4737 Answers
SOURCE: I have printed this file many times, sent file to
Try this, Press the Cancel button several times, leave it for few minutes, and then Turn off and switch on while you keep pressing the cancel button. If there's memory installed on the Dimm slot, remove it and re-install it.
Also check the print queue, Start > Printers and Faxes > double-click the printer's icon, click "printer" on the menu and select "Cancel all Documents" click "Ok" and restart both computer and the Machine. (I assume your computer with windows Operating System Installed.)
Sometimes reseating the cartridges and drum is helpful. You can give a try. But since you can make copies, I don't suspect the issue's related to the machine, but with the computer and memory.
Disconnect and reconnect the cable (usb) connecting the machine to the computer.
Good luck.
Thanks for using FixYa.
Posted on Aug 13, 2010
tonesmaker
  • 60 Answers
SOURCE: There is a display message
try to format its HDD :
turn it off..
hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again or enter . Wait for it to say "please reboot the machine", turn it off and back on. Hopefully this will work..
Posted on Jul 08, 2011
MEANING OF JOB STATUS BYPASS FEED?
It means that the paper source selected in the print job was the Bypass tray (Manual Feed). You should be able to insert paper in the tray and press OK or Continue to start printing.
Mar 02, 2015 | Office Equipment & Supplies
My Konica Milnolta c224e display massage bye pass try could not be loaded
Sure it say that exactly never heard that before doesn't say "Replenish paper"? or does it give a code or jam indication
Is there any paper on it does this happen when printing or copying ? Trying to print paper or envelope? Do the draws work OK? If printing send the print job to the machine first the when the copier states replenish paper for the bypass tray put the paper there. insure your printer perfrancies match your setting on the copier for the bypass tray, such as THICK 1 or what ever
Feb 03, 2015 | Konica Office Equipment & Supplies
HOW DO I PRINT A BROCHURE
You can put special media on side bypass feed tray. Then select paper type/thickness. Choose the bypass tray and paper type when sending print job from your PC. Job status light will blink and you need to go to the copier to execute the print job for special paper.
Sep 26, 2014 | Toshiba estudio 255 Copier
Special paper tray is empty error
Sounds like someone requested A4 size paper in a print job instead of the normal Letter size paper...
Try putting regular letter size paper in the bypass tray and then set it up as A4 size...the print job should then print out on that paper.
Apr 09, 2014 | Xerox WorkCentre C2424DN All-In-One Laser...
Paper Jam Konica Minolta BHC451
Is the thick 4 11 x 81/2? take the paper off the bypass tray, first send the job to the copier selecting the bypass tray the copier is going to beep telling you replenish paper in the bypass when you place the paper in the bypass make you follow the orientation of the paper on the copier screen.Might also want o replace the bypass tray roller set. If the Plain paper through Thick 3 work then you did not need to replace the main board. Are trying to duplex the paper????? When it jams where does the paper stop??
Dec 16, 2017 | Konica Minolta Bizhub C451 Copier Print...
No matching paper size set paper on bypass tray
Someone has told the machine to either make a copy or print from a PC to the Bypass feed tray on the copier. If you are not trying to print something by using the bypass tray then just turn the machine off, then on again to clear the request from the copier. If you are trying to print or copy from the bypass tray then simply insert the correct paper size and direction into the bypass tray slot and the machine should automatically begin printing.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Konica Minolta DiALTA Di200 Copier
My toshiba copier keeps saying job status change paper type. how do i get it off that? thank you
Your copier is likely trying to print to a different thickness of paper (ie thick 1/thick 2) then you have in whatever tray it is trying to print from. You will either have to change what is in that drawer via user functions or delete the job and try it again with a different paper type.
Sep 07, 2010 | Toshiba E-STUDIO 720 Copier
Printing on thick paper (thick 3)
You can print thick 3 only from bypass tray.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
May 27, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Green light is flashing and printer will not print. It has paper and a new toner cartridge.
try putting a piece of paper in the tray 1 (Bypass) and then pressing the green button hopefully it should print. If it does then you have sent a print job to the bypass and not the tray. If you press the green button and it prints form the tray check what media type you have set within the print driver.
Hope these work for you
Thanks J
Jan 07, 2008 | HP LaserJet 1320 Printer
Toshiba E-Studio 306 Copy Machine Logo
23 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
