Sansui au9500 there is a problem with the volume not being as loud as it should be. What could be causing this?
  • Audio Player... Master
  • 5,190 Answers
You have an old model there! A very tricky problem too! This website might help:
http://amp8.com/sansui/9500/au9500-b.htm
If it's not as loud in one channel it would be easy to suss out. But if both channels are weak that's a problem. As you can see from that website all the channels are individual driven, so it's unlikely that both channels would go down.
One thing you could try is some Servisol in the volume control, particularly if it crackles or cuts out when you turn it.
Normally if the sound goes down in both channels you look for something common to both. But it looks like the only thing common is either the volume control or perhaps the power supply?
If it is the power supply board! On that website you will see a board with fuses on it. In the centre of it is a large silver transistor marked C680. Standing for 2SC680. If that is faulty it could weaken the power to the amp. So if it is on both channels I would have a go at replacing that.
Posted on Jan 03, 2014
My sansui LCD TV won't turn on or do I have volume any ideas to fix it
What do I check if my Sansui TV Model SLED2490 will not ...
https://www.ifixit.com/.../What+do+I+check+if+my+Sansui+TV+M...
iFixitJul 9, 2014 - A friend of mine gave me a Sansui TV after a power surge caused ... led ·sansui · tv power ... The most common problem that I've researched and experienced with your tv's is that when they get unplugged, the wont turn on, just stay in ... though they'll still be frustrated, they won't trash their tv and go get a ...
I have a sansui tv and it wont turn on but is getting power ...
Nov 28, 2015 | Sansui Televison & Video
Image disappear, loud, high pitch noise
It is likely that your Sansui TV has a power supply problem.
Jan 17, 2014 | Sansui 22"" HD LCD/DVD Combo TV
Can I connect
Sansui A-80 amp already have the preamp like what
the Sansui C-77 have.
• Sansui A-80 amp could be over-driven with C-77 ,
watch for the volume level.
But you can connect it as an alternate room equalizer
if you need to.
Jul 26, 2012 | Sansui Televison & Video
Sansui sv-2012 tv volume is very low and suddenly increase
Hi srinivas_327,
This is common for some sansui televisions,
All you need to do is to go in the audio settings and turn "ON" the AUTO volume option .
This will help all your channels to have a similar volume , so you won't be surprised by sudden increase in volume.
Hope this helps ...:)
May 10, 2011 | Televison & Video
I have a sansui G9700 receiver/amp. The volume control works intermitantly. Must play with it to get volume. I believe I need to replace the potentiometer F3085. where can I get one? Erick G
The potentiometer doesn't need to be replace, it has collected dust inside causing the intermittent operation. Buy a contact cleaner/conditioner to spray inside it and move the potentiometer clockwise and counter clockwise a few times until the dust inside it is gone.
Check this link to find a contact/conditioner cleaner or you can try spraying rubbing alcohol but this could because alcohol doesn't not lubricants properties.
Let me know if you require further assistance.
Nov 27, 2010 | Sansui Audio Players & Recorders
THE VOLUME, USING THE REMOTE AND THE TV, DOES NOT GO ABOVE 50%. THIS IS NOT LOUD ENOUGH FOR THE OWNER WHO IS HARD OF HEARING. IS THERE A WAY TO INCREASE THE VOLUME. IT IS A SANSUI MODEL #LCDCD1909.
well if the volume wont go any louder on the tv even without the remote that can be a problem what i would recommend to do is get a stereo that you could hook up to the cable or satellite or if you use digital antenna use the output of a vcr to plug into a stereo system then you can use a stereo to increase the volume.
Sep 18, 2010 | Sansui Televison & Video
New Sansui 27" and remote does not work
On later model Sansui tv's, you can bring up the menu by pushing both volume buttons on the front of the set at the same time. After the menu is on the screen, you can navigate using the channel and volume buttons.
Nov 01, 2008 | Sansui TVM1916 19" TV
Low volume on playback
The volume control on the TV does not affect the recording. However, if you were recording from a set top box, and you turned the volume down on the box and not the TV, then this would cause the problem you describe.
If this is the case, then try to keep the STB volume at maximum and only use the TV volume control.
Also, some DVD players and VCRs have a lower output than the standard TV tuner, so an increase in volume is usually needed.
You might want to try some test recordings to see what happens.
May 08, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
50 people viewed this question
 Grubhead
Grubhead
