Question about Spectrum AIL 599 iRock Digital Music Studio
Transfer mp3 or midi to keyboard - Spectrum AIL 599 iRock Digital Music Studio
MD-1700 keyboard. How do I connect it via the USB port on the computer?
MIDI(Musical Instrument Digital Interface) is a standard data transfer system used exclusively for instrumentation. A side from amps 7 recording equipment many PCs, laptop & TVs have MIDI access built into them. If they can interface with a UBS connection it is more likely the exception rather than the standard. Below is a link to the users manual for your keyboard. Start reading on page 39.
http://www.manualslib.com/manual/593746/Radio-Shack-Md-1700.html?page=38#manual
Aug 05, 2015 | Image Line FL Studio 8 Fruity Edition Full...
How to solve midi connectivity issue with Yamaha keyboard?
You will need to send it in for repair is my assessment.
Mar 03, 2017 | Yamaha Audio Players & Recorders
MIDI Basics
MIDI is the language used by electronic instruments to tell each other what to play. When you press a key on a musical keyboard this keyboard will send a MIDI message to a computer or a musical instrument connected. The message says something like: start playing this note at this volume. When you stop pressing the key a new message is sent which says: stop playing this note.
MIDI messages can be transmitted using MIDI cables or USB. Old instruments had MIDI ports (round with five connectors inside) so a computer had to have a MIDI interface. Nowadays it's almost all done with usb.
The important thing to remember is that a MIDI message (and a MIDI cable) are just an instruction to play, they don't contain sound. The sound you hear when you press a key comes from the computer or the instrument connected to the keyboard, not from the plastic key you have pressed.
There is a lot more to say, but I would suggest you check wikipedia first and then come back with more specific questions.
Nov 09, 2012 | Yamaha PSR-E433 61-key Keyboard, with...
I want to transfer some midi files to my Casio LK-230 keyboard. When I plug in the usb cable it does recognize the casio unit but it does not show up on my computer...like there is not unit... How do...
The keyboard will NOT show up on MY COMPUTER as it does not have memory to record and save MIDI files... It will PLAY them real time as the computer sends the data to the keyboard. You can't transfer and save the files IN the keyboard. Some higher level keyboards do have memory and even hard drives... this one does not. This one will have some built in,that you can play but even those you cannot access as if they were memory.
With the USB cable connected, you should be able to see the device listed in the device manager section of the control panel under system hardware.
Apr 03, 2011 | Casio LK 230 Lighted Personal Keyboard, 61...
Hi, I am trying to use my Yamaha psr e323 keyboard with Ableton live 7.0.3 as a midi keyboard,the problem is that only G2 through A3 work as keys and the rest of the keys either dont work or work as MIDI...
sorry I don't know how to solve your problem, but maybe you can solve mine.. :) I also got the Yamaha PSR-E323, but mine doesn't work in Ableton (as a midi keyboard). How did you get yours to work/ how did you connected your keyboard to the computer?
I hope you can/want to help me! :)
Feb 14, 2011 | Audio Players & Recorders
I have same problem. I have recorded my performance on keyboard (PSR I425) when i transfered it to PC it's in .bup format. and the file is not getting played on PC. how should i solve it?
Transfer the data in MIDI format. The BUP format is a proprietary format to the keyboard and can ONLY be played by the keyboard. Either dump the data as MIDI format or using a MIDI interface send it to the PC or lastly, capture the audio using an audio interface on the PC.
Nov 26, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
I want to use my sd card to put my own songs and when i change the song from an MP3 to MIDI file using the program WIDI 3.3 Pro. When i put the MIDI file which is the song, into the Sd card and then into...
You need to understand what the program is doing.
An MP3 file is a recorded music performance like a phonograph record. A MIDI file is a set of instructions for performing music, like sheet music. The converter program is an attempt to turn the record into sheet music. There is no perfect way to do that. You should have gotten something out of the program, though. It sounds more like a computer problem. Try a very simple sound file, convert it to MIDI, and see if you can get something out. If your keyboard can't read it, try putting any known good MIDI file on the card and read that. Possibly your keyboard will only read certain formats or sizes or speeds of cards. See if the manual tells you anything. It might read FAT16 regular speed cards under 1 GB, for instance, and balk at a SDHC 16 GB NTFS formatted card. So, do some detective work.
Apr 05, 2017 | Casio Lighted Keyboard LK90STADMC
I am trying to install yamaha usb-midi driver software on my laptop powered by windows vista. getting this error 25001 (no device connected message). help please
I know this sounds weird, but make sure you connect the MIDI-OUT cable to the MINI-IN port on the keyboard, and the MIDI-IN cable to the MIDI-OUT port. Backwards and illogical, but there it is.. I had the same problem; now it works flawlessly.
Dec 05, 2009 | Yamaha Audio Players & Recorders
Putting on Computer what I have on Memory stick. I have saved songs from a Tyros 3 Keyboard and have difficulty putting it on Computer so that I can burn it on a CD...H E L P
Make sure you are in the song mode so you transfer just the song and not all the other stuff. Copy a song in the song mode to your USB stick, then read it on the PC. To burn it as DATA (MIDI data is data) you must use a burning program like Nero...
If you are trying to make an audio CD that is a different story as you need to convert the MIDI file to an audio format such as MP3 or WAV before burning and AUDIO CD.
Oct 19, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
My MIDI won't play back even when I play the file, no matter which program I use to play it. The computer I use is a Compaq Presario, I have Cakewalk Home Studio 2002 on it, and my sound card is SB X-FI...
The default MIDI setting of your PC may have been set for another MIDI device (for example, if Cakewalk Home Studio has been used with a MIDI compatible keyboard). Go to... Control Panel / Sounds and Audio Devices / Audio / MIDI music playback and change the setting back to your soundcard (and set as default if you prefer).
May 03, 2009 | Computers & Internet
Spectrum AIL 599 iRock Digital Music Studio Logo
65 people viewed this question
Top Spectrum Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Spectrum Audio Player and Recorder Expert? Answer questions, earn points and help others
