Question about Jeep 2006 Grand Cherokee Laredo
Water oon passenger floorboard
Water build up on passenger side floorboard when its not raining or a/c running
Mikey108
  • 475 Answers
SOURCE: water leak
The drain is an opening on the passenger side of the car on the firewall towards the bottom.
Posted on Oct 15, 2008
maroon377
  • 3 Answers
SOURCE: AC leaks condesation in my 1996 jeep GC
keeper of fire here is mostly right...however, on my 96 grand cherokee with the 5.3 liter V8, there is a slight design flaw...the evaporator tube is actually IN the framing...
this baffled me for a time, until a local jeep mechanic told me that this was regular in a jeep zj, and that all i had to do was pull back the carpet on the psg side and drill (yes drill) a hole into the plastic so you can stick the wire in, or an air hose and unclog your tube from there...then you silicone it back up and tada!! be sure however that before you drill willy nilly that you are actually drilling in the right spot, this can kinda be found by following what bit of hose is visable and seeing where it disapears into the floor...and its a little black plastic circle that you will drill into...hope this helps!
Posted on Apr 06, 2009
old marine
  • 1983 Answers
SOURCE: Water coming in to front passenger floor when it rains
The heater/airconditioner box under the dash has a drain hose to allow condensation to drain when the air conditioner is running. If this hose gets plugged, rain may accumulate in this box also (if it's raining heavily), as it comes in through the fresh air intake.
Look on the engine side of the firewall, probably on the passenger side, for a hose coming through the firewall that is not connected to anything. It is usually short, has a 90 degree bend, and the open end is down. Make sure that the end of this hose is not plugged.
Posted on May 11, 2009
  • 6982 Answers
SOURCE: drain line stopped up
You are correct...Look for a small rubber hose protruding from the firewall on the passenger side about even with the bottom of the inside heater box. do not stick anything hard in there or you can damage parts. usually just working it a bit or sticking your finger in there will get it flowing again.
Posted on May 27, 2009
  • 677 Answers
SOURCE: water on passenger floorboard
Iside the car,in the middle of the console is a shallow tray.Its job is to catch the codensation that drips off the aircon.Same as you see hoses coming off home aircons.this is what is in the car.There is a hose,about as thick as a finger,that drains the codensation out through the firewall of the car and into the rear of the engine bay to the ground.There may be 2 hoses.One either side if its a split catchtray.The hose has either been knocked off or is blocked.Usually blocked.The tray itself gets dirt in it and this is where 'gunk' can buildup over the drain hole.Find the hose and shoot some compressed air up the hose or run some line trimmer cord up there.Hope this helps
Posted on Sep 19, 2009
Water on drivers side floorboard . Why?
If you have a sunroof it could be the drain that follows the front pillar letting out under the front fender. These hoses are known to plug and crack open releasing water into the floorboards.
Driver side door check along top and front edge for tears or twisted looses sections. Internal to the door water can drain down along the window and is released outside the door seal. If the bottom of the door has the opening that releases the water plugged then water will drain over into the floorboard.
Jan 06, 2016 | Cars & Trucks
Water is running under my dash onto floorboard in my 2007 dodge caliber after it rains. Where is the water comming from
You need to find the conduits for rain - one of them has a leak in it probably from corrosion. Try to locate just where the water is getting in and see if you can use a sealer to stop the water from getting in.
I would remove the glove box and anything else in the way and look for the source when hosing down the car.
Nov 22, 2015 | 2007 Dodge Caliber SXT Sport Hatchback
Water leaks onto the passenger floorboard during heavy rain
Floor plug or plugs have fallen out most likely.There Should be some plastic plugs under the floor board outside. Look to visualy check to insure they are still in one piece.
A busted heater core will flood the passenger side floorboard when the heat is turned on.
Feb 22, 2011 | 1997 Ford Escort
1998 Volvo C70 - water on floorboard after rain. Hi, anybody out there having experienced water on the floorboards after rain? My Car is always parked outside on the street, so the weather goes to work on...
most likely cause is water intrusion through the cabin filter
pull the filter
if wet then you need to find something that diverts water away
many OEM's have had this problem but nothing on file for this vehicle
Sep 26, 2010 | 1998 Volvo C70
The passenger side floorboard gets wet =
is it only when the ac is on? there is a pan under the ac unit that has a hole in it to allow the condensation to empty. if that hole gets plugged it could cause the condensation to build up and back into the inside of that car. i unplugged mine and floor stayed dry
Jun 03, 2010 | 2005 Chrysler Town & Country
Water collects in the passenger floorboard after a rain.
do to condensation build up the a/c drain gets plugged and that water has no were else to go but on the floor board the drain is located under hood on left side of firewall about six inches down from top
Feb 06, 2010 | 2004 Chevrolet Impala
Water in floorboard after every rain. 95 Dakota
the windshield could be leaking behind the dash,a good way to check is put the fan of the heater on,hot or cold and get a solution of soapy water and apply to the outer edges of the windshield and look for bubbles.
Oct 27, 2009 | 1995 Dodge Dakota
My 2005 taurus has started getting a pool of water on the passenger side floorboard after a heavy rain, any ideas on how to fix, didn't see any leaks from windshield.
Look for moisture on the glass of the windshield, as well as the passenger side door, if thebottom seal isnt making contact on the door glass water will run in threw the door
Oct 09, 2009 | 2005 Ford Taurus
Jeep 2006 Grand Cherokee Laredo Logo
26 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
