Question about VAX Appliances Vax X5 Bagless Upright Cyclonic Vacuum
Isn't sucking up dirt and rollers aren't turning
  • 55 Answers
Belt off or roller frozen mine was full of hair
Posted on Jan 02, 2014
Vacuum is not sucking up dirt, need to know to replace belt
lay vacuum flat and left up head you well see the brush or roller you well see holes on the bottom you well need a phillips screw-driver remove all screws,make sure its unpluged after all screw are out pry bottom apart you well see belt replace and clean it out if you can remove string,hair from roller and dirt from the ends of the roller reasemble and it should work like new thanks.
Nov 30, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
My bissell 3120-3 is not sucking up dirt
if the vacuum is not sucking up dirt first check the hose to see if there is suction if you dont have suction there you need to follow the hose to the nearest connection remove the hose from there using screwdriver or some models will twist off check to see if there are any blockages, make sure the bag is not full if so replace bag with new one if needed, if bagless or if that dosent resolve the problem remove the cover plate for the roller, remove the roller and check the suction port that routes the dirt and debris to the dirt cup or the bag. you will just need to check all of the different routes to the bag or dirt cup, the best thing to have is a blower and you can blow through the different passways untill the clog is blown out, thanks I am sure that this info will help everyone if in alb visit the Vacuum Doctor, Don the doctor is always in!!!!!!!!!!!!
Oct 31, 2009 | Vacuums
Carpet roller will not turn. Vacuum still sucks up dirt
You may need to replace the belt that drives the roller head. They wear out and break, or maybe it has just come loose. Also check for string and thread wound around the roller wheel axles, that is a common "culprit"
Jul 21, 2009 | Kenmore 23913 Progressive PowerMate Bagged...
No Suction
it is probably the dirt fan. u may have to get it serviced
Jul 09, 2009 | Dirt Devil Featherlite Bagged VacuumVacuum
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Dirt devil vaccum #088915 won't pick up.
well the first thing i would look for is if the brushes turn turn it over bump the on off switch if it turns the belt is fine but u might have a clog in the bottom if that the case have to pull cover from thhe bottom take the belt and roller brush off and look up insde where the junk sucks up use a wire hanger if u need and after that clean out where the dirt goes in bag or canister........hope this helps
Dec 16, 2008 | Vacuums
Help!!!!
it's likely wrapped around the brush
pull out the roller and un tangle it
Aug 12, 2008 | Dirt Devil M084600 Dynamite Bagless...
Vacuum will not pick up, the dirt just lays inthe bottom of the hose and does not get sucked up,i looked for aclog but there isn,t one
Are the filters clean? Is the brush roll turning? Otherwise check the dirt inlet by the brush roll for a clog. Pull the hose off from the bottom, is there suction there? If there is, then the problem is below where the hose is pullged into. If no suction, then there is a clog in the hose, take it off, (if it comes off completely), drop something like a heavy marble down the hose and see if it comes out or not.
Jun 16, 2008 | Dirt Devil Vacuums
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
VAX Appliances Vax X5 Bagless Upright Cyclonic Vacuum Logo
Top VAX Appliances Vacuums Experts
seanwalters1
Level 1 Expert
Tom Chichester
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
